February 23, 2016, 06:47 |
Full Multicomponent Diffusion
Rep Power: 11 |
So apparently a Full Multicomponent Diffusion is only possible for 3 or more species?! Why can't I simulate diffusion with 2 components?
February 23, 2016, 06:53 |
Cees Haringa
Well, it's called multicomponent diffusion, right? So, there will have to be at least 2 diffusing species in a carrier; having 2 components, there is 1 diffusing species in a carrier.
February 23, 2016, 07:34 |
Rep Power: 11 |
Yes I get that, but is diffusion then implicitly accounted for (maybe in fickian diffusion?) or not calculated at all? What alternatives do I have?
Though I don't understand why maxwell stefan equation is only valid for N>2 ? Shouldn't it go over to the simple 2 component fickian diffusion? |
February 23, 2016, 08:08 |
Cees Haringa
fickian diffusion is included in the species tracking model by default. Of course, you do need to give in a diffusion coefficient (under materials)
February 23, 2016, 08:59 |
Rep Power: 11 |
Are you talking about the panel:
Species Model -> edit mixture material -> mass diffusivity (m2/s) ?? I specified kinetic theory so far...Though I do not quite get how ansys gets the right coefficients from that?! manually would be which option: constant-dilute-appx dilute-approx unity-lewis-number multicomponent ? |
February 23, 2016, 09:53 |
Cees Haringa
I typically just throw in an experimental value, so constant dilute approx.; can't help you on the other options... sorry, hope someone else can.
February 24, 2016, 02:19 |
Lucky
Rep Power: 66 |
You don't need to activate the multicomponent diffusion option if you only want to do diffusion of 2 species.
Diffusion with 2 components is generally not "called" multicomponent diffusion, it's diffusion. |
Full Multi Component Diffusion is inactive | Alek | FLUENT | 1 | September 26, 2014 10:30 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Multicomponent diffusion modeling | gsbhatia89 | CFX | 2 | June 8, 2010 19:31 |
multicomponent diffusion | katya | FLUENT | 0 | November 24, 2004 11:31 |
