When is the best time to increae Under-Relaxation factors? |
February 21, 2016, 18:45 |
Aja
Rep Power: 15 |
I am simulating a turbine. But I don't know that how use these URF. First, I decrease URFs but When is the best time to increae Under-Relaxation factors? Thanks. |
February 23, 2016, 08:22 |
Rep Power: 13 |
If you think your simulation is stable you can increase them.
February 23, 2016, 15:55 |
Aja
Rep Power: 15 |
February 24, 2016, 02:13 |
Lucky
Rep Power: 66 |
It means if your simulation doesn't diverge or is otherwise marginally divergent. You should always use the highest URFs as long as it doesn't cause your simulation to diverge, reducing them only if you have stability problems and then increasing them back to their defaults if possible. The defaults are generally optimal, but you can achieve faster convergence by increasing the URFs above their defaults.
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Convergence with reduced under relaxation and time scale factors | saisanthoshm88 | FLUENT | 0 | March 19, 2013 11:08 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
relaxation factors and time accuracy | Mike | Main CFD Forum | 7 | May 21, 2005 13:41 |
