February 16, 2016, 11:26 |
Moving Reference Frame.
Dhyan Shnkar
HI,
I am confused regarding a problem that has a rotating solid part and water (fluid domain) flowing over it. I have taken solid as a separate zone and there is an interface between the solid and the fluid region. I have given a zone rotation for the solid using Frame motion. But its not working. Problem solves when I give wall motion instead. Please help me with the problem regarding MRF. Thanks in advance! |
November 23, 2018, 04:12 |
Büşra Eren
Rep Power: 8 |
You should be careful about rotation axis and origin. You may as well try transient simulation. Also you need to set your wall as moving rotating as your domain and axis origin must be same as your domains.
interface problem, mrf |
OF211: ThirdParty and /src compiled, but not /applications... | vkrastev | OpenFOAM Installation | 8 | October 18, 2012 15:53 |
Moving Reference Frame (MRF) with UDF | Tobard | FLUENT | 0 | April 14, 2011 15:18 |
the difference between moving reference frame and moving mesh | radix | FLUENT | 0 | December 30, 2009 06:02 |
Help for Moving Reference Frame. | aiqch | Main CFD Forum | 0 | April 3, 2009 00:23 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
