Odd dimensions on import into fluent
Like Tree1Likes
  • 1 Post By LuckyTran
Old   February 15, 2016, 18:13
Default Odd dimensions on import into fluent
Mark Schulte
Jehosh is on a distinguished road
Using workbench, I create my geometry using DM and am careful to put the corner of my rectangular geometry constrained at the origin. However, when I bring it into Fluent, my y dimensions don't start at the origin, but rather 3.636196e-37m. Beyond just not looking clean, does it matter? If so, how can i fix it? I have tried rebuilding it, but still get the same nonsense, just with slightly different values.
I appreciate any help you can give.
Cheers, Mark
Jehosh is offline   Reply With Quote
Old   February 16, 2016, 01:06
Lucky
It's very common and I wouldn't worry about it unless you actually encounter an error. It can be introduced at various stages, from the original mesh, to saving the mesh, to importing the mesh, or during conversion of the mesh scaling (from m into inches, etc).
Jehosh likes this.
Old   February 16, 2016, 10:40
Mark Schulte
Awesome. thanks so much. That is what I was hoping.
constraints, dimensions, fluent, scale
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
How to import Autodesk Inventor .ipt file into ANSYS FLUENT? soetommy FLUENT 0 September 27, 2011 01:35
Import CFX def into Fluent eric_wang FLUENT 0 April 18, 2011 14:14
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
import on fluent Valerio FLUENT 0 July 9, 2007 09:10
