DOM radiation / solid boundary
Like Tree1Likes
  • 1 Post By vucrusader
Old   February 2, 2016, 14:45
Default DOM radiation / solid boundary
vucrusader is on a distinguished road
All,
I am currently modeling a simple vacuum enclosure that is receiving an external radiation input through a window. I want the radiation to strike a particular surface and heat it.
In order to use through DOM method within the vacuum enclosure I have filled it with 'air' with a thermal conductivity set to 1e-10. The material being directly irradiated is a non-moving fluid (constant velocities set to 0) which only accepts radiation at its boundary and does not participate in radiation. The interaction between the 'air' and the irradiated material is modeled using a boundary (air-side) and its shadow boundary (material-side). I do not understand how to properly set this boundary so that radiation from the DOM passes through the boundary and is fully absorbed by the material.
Any advice would be greatly appreciated.
Regards,
Milan2013 likes this.
vucrusader is offline   Reply With Quote
dom, irradiated boundary, shadow boundary
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
