How to model particle-particle interaction in DPM
Like Tree1Likes
  • 1 Post By Shevin W.
Old   January 13, 2016, 04:08
Default How to model particle-particle interaction in DPM
S. Morichika
Saidul is on a distinguished road
Hi All,
I am trying to model particle transport in DPM. I am also trying to consider the particle-particle interaction. I have enabled the DEM Collision from the physical model tab.After running the simulation I got an error message.
Updating solution at time levels N and N-1.
done.
Injecting 1016 particle parcels with mass 1e-25 at t = 0
DEM: Memory allocation for collision mesh failed.
Collision mesh width is very small which will give rise to a
huge collision mesh. Consider inspecting your injection setup.
Maybe the number in parcel is not what you want.
DPM Iteration ....
Error: Out of memory.
Error Object: #f
Can anyone help me out to fix this problem. I have also unchecked the adaptive collision mesh width and it enabled static collision mesh width. After changing that I didn't get that error message and the model can't inject particle. Here are the details:
Deleted 1016 particles in injection injection-0 with total mass 1.000000e-25 kg
Deleted 1016 particles in injection injection-0 during transient iteration
number tracked = 0, escaped = 0, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0
5 1.6035e-01 3.4680e-04 3.1846e-04 2.4847e-04 0:00:00 0
Advancing DPM injections ....
Flow time = 0.0001s, time step = 1
3499 more time steps
I am badly looking for some help. Thank you for your help in advance. Thanks a lot.
Best Regards,
Saeed
Saidul is offline   Reply With Quote
Old   February 2, 2016, 06:17
Hassan Mroue
mroue is on a distinguished road
Send a message via Skype™ to mroue
Injecting 52 particle parcels with mass 1e-23
number tracked = 52, escaped = 0, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0
355 4.7819e-04 3.4900e-04 3.3649e-04 2.0866e-07 4.8629e-04 1.1605e-03 0:00:24 145
356 4.8052e-04 3.4872e-04 3.3606e-04 2.0747e-07 4.8468e-04 1.1545e-03 0:00:19 144
357 4.7625e-04 3.4845e-04 3.3553e-04 2.0596e-07 4.8302e-04 1.1479e-03 0:00:15 143
358 4.7067e-04 3.4807e-04 3.3507e-04 2.0472e-07 4.8141e-04 1.1415e-03 0:00:12 142
359 4.7059e-04 3.4775e-04 3.3454e-04 2.0357e-07 4.7983e-04 1.1368e-03 0:00:10 141
Deleted 23 particles in injection injection-0 with total mass 4.321220e-24 kg
Deleted 29 particles in injection injection-0 with total mass 5.678783e-24 kg
Any idea how to solve this problem?
mroue is offline   Reply With Quote
Old   August 29, 2019, 10:59
Default call for your help
Melanie
wang201908nuo is on a distinguished road
Have your problem been solved? Can you help me? I have the same problem.
wang201908nuo is offline   Reply With Quote
Old   August 29, 2019, 11:29
Melanie
Hi, have your problem been solved? I have the same problem, wait for your help.
Originally Posted by Saidul View Post
Hi All,
done.
DPM Iteration ....
Error Object: #f
Best Regards,
Saeed
Old   May 29, 2021, 04:56
Shevin W. is on a distinguished road
This problem can be solved by increasing the injected mass-flow rate, such as 1e-25 -->1e-10.
Sai91 likes this.
Shevin W. is offline   Reply With Quote
dem, dpm, particle interaction
In DPM model, with rosin-rammler particle size distribution described problems, thank fa84a8g779 FLUENT 1 July 11, 2013 22:30
DPM particle tracking sajeesh FLUENT 0 May 12, 2013 03:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
forced to sticking of soot particle kmgraju CFX 0 November 27, 2012 10:08
interaction time between particle and eddies Steve FLUENT 0 April 10, 2001 19:17
