January 11, 2016, 00:50 |
Backflow turbulent intensity?
Jongmin Choi
Rep Power: 10 |
Hi, I'm beginner of ansys fluent.
As doing tutorials I have a question about backflow turbulent intensity. I haven't learned any knowledge about that so I couldn't understand it. Could you explain about backflow turbulent intensity? How could I decide that value for ansys fluent??? |
January 11, 2016, 15:41 |
Lucky
Rep Power: 66 |
When there is backflow, your outlet is an inlet. Thus you need to specify back-flow conditions in the event that there is any back-flow. Just as you might specify pressure, temperature, turbulence, etc at inlets, you need to do the same for outlets.
Just take your best guess as to what a suitable value is. If you knew what the backflow turbulence was, then you would already know the flow field and wouldn't be doing CFD in the first place. Last edited by LuckyTran; January 27, 2016 at 03:41. |
January 27, 2016, 03:17 |
Jongmin Choi
Rep Power: 10 |
Thank you for your sincere ansewering
September 7, 2016, 15:49 |
#4 | |
Abdulaziz Abutunis
Rep Power: 12 |
First of all, thanks for your answer and could you please specify if the turbulence intensity affected by the application. for example if it is a rotor then the turbulence intensity will be higher than if it is a static object facing the flow. And in case of airfoil, should the turbulence intensity at the inlet be little larger than at the outlet. Thanks Aziz |
September 7, 2016, 16:00 |
Lucky
Rep Power: 66 |
The backflow turbulence intensity is affected by everything. Yes, it depends on each individual application.
The turbulence intensity is a local variable. It may locally decrease or increase depending on the local details of the flow. The turbulence intensity in the freestream can decrease because of decaying turbulence whereas the turbulence intensity can be enhance by the wake of a rotor/stator. |
January 11, 2024, 03:53 |
nawres
Backflow Turbulent Intensity (BTI) is a measure of the turbulence intensity in the backflow region of a fluid flow. It is defined as the ratio of the root-mean-square (RMS) velocity of the backflow to the mean velocity of the main flow. BTI is an important parameter in the design of fluid systems, as it can affect the performance and efficiency of the system.
BTI is typically caused by a sudden change in the flow direction, such as a bend or a valve. When the flow encounters a sudden change in direction, it can create a region of recirculation, or backflow, behind the obstruction. The backflow region is characterized by high levels of turbulence, which can lead to a number of problems, including: Increased pressure drop Reduced flow efficiency Noise and vibration Cavitation Erosio |
backflow |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Question regarding Reynolds Number and Turbulent Intensity | maxj | Main CFD Forum | 4 | March 5, 2013 07:16 |
k-epsilon: Defining turbulent intensity and length scale? | klausb | OpenFOAM | 0 | January 23, 2011 08:28 |
Turbulent intensity | swe704 | Main CFD Forum | 0 | November 13, 2009 04:42 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 01:05 |
