January 8, 2016, 13:58 |
Flow past a cylinder
VISHNU
Rep Power: 10 |
while simulating unsteady flow past a cylinder I always get the value of CL to be near to zero though drag values fall within limit ?? Why does this happen even after i wait for 100s of flow?
January 9, 2016, 19:06 |
You should post more details to get proper help. What is the flow conditions you are using? Velocity? Reynolds number? Laminar? Turbulent? Viscous model? Reference Values you use? Coupled or Segregated Solver?
January 10, 2016, 03:20 |
amirhossein
Rep Power: 12 |
major problem in your case is that you not set references value
January 16, 2016, 12:15 |
VISHNU
Rep Power: 10 |
The above problem was solved but has the below mentioned trouble now.
With Re=100,v=1m/s,density=100.When i simulate an unsteady flow I always get the Cl to be greater than 0.3 eventhough the frequency is .16(St=.16). Why I am not getting the value of CL<0.26?? Please help..My cylinder dia is 1m |
January 19, 2016, 04:37 |
#5 | |
amirhossein
Rep Power: 12 |
is it set to 1 ? cause Reynolds number need it too and another thing , what is your solver ? |
January 20, 2016, 04:42 |
VISHNU
Rep Power: 10 |
Dynamic viscosity is set to one...I have tried with both simple and coupled solvers(QUICK SCHEME) 2nd order implicit with standard initialization
January 20, 2016, 13:05 |
amirhossein
Rep Power: 12 |
January 21, 2016, 06:53 |
VISHNU
Rep Power: 10 |
Mesh is very fine..No of elements is around 40,000.Flow domain is 16mx32m
January 21, 2016, 07:08 |
#9 |
amirhossein
Rep Power: 12 |
January 21, 2016, 12:18 |
#10 |
VISHNU
Rep Power: 10 |
I tried with different biasing and no of elements..But still Cl value exceeds .3.
February 18, 2016, 06:19 |
Implement boundary condition
#11 |
VISHNU
Rep Power: 10 |
Could you please tell me how to call a particular Boundary condition after a certain no of time step is reached using UDF?
2D modelling of flow past a rotating cylinder | pds24 | Main CFD Forum | 1 | August 21, 2015 11:50 |
Flow past an oscillating cylinder (Strouhal number) | o_mars_2010 | Main CFD Forum | 8 | May 23, 2014 05:25 |
Flow past rotating cylinder | sam.ho | OpenFOAM Running, Solving & CFD | 4 | October 10, 2013 08:49 |
CFD help: flow past cylinder | harsha00711 | Main CFD Forum | 1 | December 24, 2010 22:19 |
meshing for flow past a cylinder | karthik | FLUENT | 1 | July 15, 2005 07:17 |
