Frederick Emmanuel Vincent
Rep Power: 0 ![]() |
0 (..\src\mpsystem.c@1172): mpt_red: failed: errno = 10054
0: mpt_read: read failed trying to read 8 bytes: No error MPI Application rank 0 exited before MPI_Finalize() with status -1 This was the error I receive when I try to run my case in the parallel processor . I receive this error after 2 hours, in every case file while running. Independent of mesh size and what ever case is fired in that particular system. System Configuration Windows8, 32 GB RAM, I7 Processor. I request you to give me a solution. I wasn't able to fire any case in that system more than 2 hours. Last edited by Fredy7_me; December 12, 2015 at 05:42. Reason: Extra words to be added |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Are you running this on your system that you setup and have control over?
Does this error occur by itself with no other errors? Or does it happen with another event like say an autosave? This mpi error occurs when the threads lose communication with other threads. If running remotely this can be caused by a dropped network connection. Even when run locally, your mpi may be running over the network. I would check your system settings to make sure your processors, hard disk, and network devices are not going into sleep mode (check the power settings). |
Thank you Lucky.
I have checked my system power settings, everything works fine. The runs gets stopped exactly after 2 hours. But all the networks were working fine all the time. I need to make sure that is it because of fluent license issues or is it because system issues. |
error 10054, mpi finilize, mpi fluent errors |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
