khar nab
Rep Power: 16 ![]() |
Hi all,
I have read Fluent documentation for aeroacoustics problems. It mentions three approaches among which the direct method is the most accurate but computationally expensive. However, there are no details on how to apply it contrary to the other methods. Can someone explain what is the direct method and how to apply it? Thank you in advance NK |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
The direct method is to simply run a transient simulation with small enough time-step and fine enough grid to resolve spatially and temporally the acoustic waves (pressure waves).
This method is extremely prohibitive in terms of computational cost and memory (since the acoustic waves are usually much faster than convective speed, and wavelength of acoustic waves are much smaller than hydrodynamic length scales). Numerical damping also usually kills such waves. For example it's well known that even a 2nd order backward euler scheme in time is too dissipative and fourth order scheme is necessary. |
khar nab
Thank you LuckyTran,
I am interested in jets within small domains which should be ok for the direct method. How is the feedback loop accounted for in such cases? Does Fluent solve modified Navier-Stokes equations in the direct method? Then, I guess it is a question of postprocessing. Usually, the most important results are contours of pressure waves to determine the sources, sound level through temporal profiles and characteristic frequencies. Could you, please advise on how to get these in the direct method? Best regards NK |
Lucky
Unless I am wrong about the "direct method" otherwise:
You would just run a transient simulation and plot the instantaneous pressure. You might need to initialize it and perturb the initial pressure field to help generate the acoustic waves but that's the general idea. |
khar nab
Thank you again for your answer,
I will appreciate if you could clarify your comment "You might need to initialize it and perturb the initial pressure field to help generate the acoustic waves" Best wishes NK |
Lucky
To solve a problem you need:
the governing equations (the pde itself) boundary conditions initial conditions You need the correct initial conditions for your problem to evolve in a meaningful way. |
#7 | |
Jingchang.Shi
Rep Power: 14 ![]() |
Thank you! |
#8 | |
Jingchang.Shi
Thank you! |
What is C.V. based finite element method | C-H Kuo | Main CFD Forum | 4 | September 19, 2022 14:06 |
addCmptAvBoundaryDiag method | santiagomarquezd | OpenFOAM Programming & Development | 3 | December 26, 2020 08:29 |
Lattice Boltzmann method vs Finite Element Method and Finite Volume Method | solemnpriest | Main CFD Forum | 3 | August 12, 2013 11:00 |
Need help understanding an Integral method | jwoolsto | Main CFD Forum | 0 | November 9, 2011 16:07 |
Multigrid method | Suresh kumar | Main CFD Forum | 1 | April 24, 2006 20:07 |
