Simple question: Opening Fluent from Workbench vs opening directly?
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   November 18, 2015, 06:23
Default Simple question: Opening Fluent from Workbench vs opening directly?
Ericson
Ericson is on a distinguished road
What is the diffrence between opening fluent from workbench and opening fluent directly?
in this case we have meshing file..
Ericson is offline   Reply With Quote
Old   November 25, 2015, 17:12
Jim
CFDYourself is on a distinguished road
they are both the same program. there's no real difference.
Opening in workbench is good for:
- meshing
- advanced functionality in workbench (such as design optimisaitons)
- comparing several results
- postprocessing in CFD post
Opening in fluent standalone is good for:
- running UDFs
- high load simulations.
in my work I use fluent standalone exclusively, then import the data afterwards if I want to use CFD post.
CFDYourself is offline   Reply With Quote
Old   October 6, 2021, 19:30
Mouna
Mounarah is on a distinguished road
Hello, please how to save a fluent standalone file and how to open the results in cfd post after finishing running in standaone. Thanks
Mounarah is offline   Reply With Quote
Old   October 7, 2021, 01:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
file -> write -> case and data
read case and data in cfd post
Mounarah likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 7, 2021, 08:01
Mouna
Thanks Alexander. For the saving i have 2 options either write case and data which is a manual method or autosave which would be automaticaly or i should do write case and data before running the cas and then i apply autosave. Thanks for clearing
Old   October 13, 2021, 05:14
Moritz Kuhn
MKuhn is on a distinguished road
You need only to save the case-file once and then only if you change some settings (boundary conditions, solution methods, models and so on). Save the data file after the solution. You can also write the data file before the solution, in this case you have only the initialization data in it.
Use the autosave function to save the data file
* for longer steady state problems, to prevent the loss of solution data if the solver crashed
* for transient problems, if you are interested in the data for certain time steps.
Be careful for large case files, short intervalls will produce many files and much GB. There is an option to retain only the recents files.
MKuhn is offline   Reply With Quote
Old   April 19, 2023, 12:15
Default Question about ROM models
Nicely
thesis-bloke is on a distinguished road
Is there a possibility of me using a ROM directly through a standalone fluent? using a case and data file does not provide the extraction of ROM results which is tragic. Can anyone help me with this, its for my thesis project.
thesis-bloke is offline   Reply With Quote
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
Simple Beginner User Question on 'geometry' scottimus FLUENT 5 March 27, 2012 14:17
Question about transiet simulations in Fluent Vitaly FLUENT 5 February 19, 2012 23:06
Iterative solution within Workbench and Fluent? WiscMS ANSYS 1 December 18, 2010 11:03
