Insert data of existing Flow Field
Like Tree1Likes
  • 1 Post By Zerzura
Old   November 5, 2015, 04:47
Default Insert data of existing Flow Field
Zerzura
Zerzura is on a distinguished road
Goodmorning/afternoon/day,
I have a problem with solving my simulation of drug distribution in the arterial wall. The solution is not converging when I solve both the velocity profile and the User Defined Scalars (UDS) at the same time.
Therefore I want to first solve the velocity profile and use that velocity profile to solve the UDS distributions.
My plan was:
- solve the velocity profile
- load .cas and .data file
- add the UDS and source terms
- turn of the function at: solve/solution-controls/equations/flow
- get a fully converged distribution of the UDS and maintain the flow field
However after running the simulation again, the flow field has changed drastically.
Please can someone give me advice how to implement the flow field and not let it be changed afterwards?
Your help is much appreciated.
~me
AP3181 likes this.
Zerzura is offline   Reply With Quote
Old   November 6, 2015, 13:41
Lucky
I think you should already have it, your approach should work. Are you running this remotely on a cluster? You might have given the wrong commands. You TUI commands you should be using are:
/solve/set/equations/flow n
Also remember to disable any turbulence, temperature, etc. Check to make sure you actually turned off the equations properly.
Old   November 9, 2015, 11:56
Zerzura
thank you!
I made another mistake, it was not loading the data-files correctly .
This method is correct however
flow field, solution controls, uds
funkySetBoundaryFields - Manipulation of existing field jhertel OpenFOAM Pre-Processing 16 May 18, 2020 07:32
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Injection of partical into flow field M.Mahendran FLUENT 2 November 24, 2002 01:54
