October 1, 2015, 10:50 |
Passive scalar in "frozen" field
Rep Power: 11 |
I am trying to solve the mixing of a passive scalar in a tank. Since only the transport of the scalar is transient and the rest of the flow is steady-state (more or less) i would like to solve only the transport equation for the scalar in the flow field from a steady state simulation. Can I do this using Fluent and UDS? |
October 4, 2015, 16:18 |
Lucky
Rep Power: 66 |
I tried this with the energy equation not too long ago and it didn't work. All I did was disable the flow solver & turbulence, nothing fancy. If someone knows of a way to solve transport equations with a frozen velocity field (i.e. a stationary velocity field), I am also extremely interested.
October 5, 2015, 06:28 |
Rep Power: 11 |
It seems like it worked for the scalar transport however. Ran a steady state, changed to transient and turned of flow and turbulence solver, then continued. What did not work with the energy equation?
October 5, 2015, 10:41 |
#4 | |
Lucky
Rep Power: 66 |
I actually did this ~1 year ago so my memory is a bit fuzzy.
Maybe I'll try this again and post results. I still have the case and data file somewhere. Maybe I am wrong. Since it worked for UDS it should work for energy as well. Ok so I did run a simple pipe flow case with energy and disabling the flow solver and it works. I remember having difficulty with it before. Sorry about that. Last edited by LuckyTran; October 5, 2015 at 20:25. Reason: update |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 08:30 |
Passive scalar transport | novyno | OpenFOAM Running, Solving & CFD | 10 | May 5, 2016 14:31 |
passive scalar with simpleFoam | Uyan | OpenFOAM Programming & Development | 2 | March 1, 2016 11:07 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 02:47 |
