How to plot blending function F1
Like Tree1Likes
  • 1 Post By MiloslavDohnal
Old   September 23, 2015, 08:29
Default How to plot blending function F1
Miloslav Dohnal
MiloslavDohnal is on a distinguished road
Hello FLUENT-ers
I'd like to ask you if there is some possiblity to plot contours of blending function F1 in FLUENT or CFD-post? I'm doing some literature overview how to check mesh quality for scale-resolving simulation (SAS model) as a part of my Ph.D. thesis. I've found that some authors, e.g. http://www.researchgate.net/publicat...le_spray_dryer, showed spatial distribution of the blending function to see where SAS falls back to RANS solution and where not. However, they've done this in CFX
From this point, seems like it's a know-how of the authors. Is it possible to simply plot contours of the blending function F1 or some UDF needs to be written to plot it?
Thank you a lot for any answer
Regards
Miloslav
MiloslavDohnal is offline   Reply With Quote
Old   March 11, 2016, 10:24
Ofcozz is on a distinguished road
im working on the same issue. Did u find out how to solve this?
thx in advance
Ofcozz is offline   Reply With Quote
Old   March 11, 2016, 11:30
Miloslav Dohnal
Yes, i've already solve it. You have to turn it on via TUI. Unfortunately, I am on vacation and I don't remember the command. I will be back in office next monday. I will post it as I return.
By that time, you can try to google it. Should be something like:
/solve/set/expert and then some yes and no commands.
Good luck
Old   March 13, 2016, 11:02
thank u very much, i restarted my calculations and i hope this will fix my problem
Old   March 21, 2016, 04:20
Miloslav Dohnal
Hi Ofcozz,
I finally came back to my office and posting here part of my journal which turns on the possibility to plot blending function. Bellow is the TUI command which works fine without any problems for me. You can find it under contours / turbulence
Good luck with blending functions
; Turn on blending function
/solve/set/expert/ n y n
Leonardo.flores likes this.
blending function f1, sas-sst model, sst k-omega
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
In Post-First blending function for BSL and SST anna CFX 2 September 24, 2011 19:27
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 14:38
