Extracting Average Nusselt Number of a vertical Solar Chimney directly from Fluent
Like Tree2Likes
  • 1 Post By LuckyTran
  • 1 Post By Bruno Machado
Old   September 19, 2015, 11:32
Default Extracting Average Nusselt Number of a vertical Solar Chimney directly from Fluent
Abayomi T. LAYENI
yomilayeni is on a distinguished road
Send a message via Skype™ to yomilayeni
I have challenges extracting the Average Nusselt Number directly from the simulation by Fluent. The local heat transfer coefficient of the wall is available directly from the simulation and I require directly from the simulation also the Average Nusselt Number.
yomilayeni is offline   Reply With Quote
Old   September 19, 2015, 12:20
Lucky
You can compute it from Reports>Surface Integral or you can make a surface monitor.
yomilayeni likes this.
Old   September 19, 2015, 16:16
Bruno Machado
Bruno Machado is on a distinguished road
As LuckyTran said, you can get t by the surface integral. Do not forget to adjust the reference values (properties, length, etc.) for your case, because they are used to compute the mean and local Nusselt number.
Bruno Machado is offline   Reply With Quote
Old   September 21, 2015, 01:08
Abayomi T. LAYENI
Thanks. It does work. How do I make a surface monitor though?
Old   September 21, 2015, 01:10
Abayomi T. LAYENI
How do I adjust the reference values? I thought the surface integral and selection of the name section takes care of that.
Old   September 21, 2015, 05:28
Bruno Machado
in the solution setup menu, there is a link to the reference values area.
Old   September 22, 2015, 14:13
Abayomi T. LAYENI
Thanks Bruno Machado. I seem no to be able to find the Solution set up menu you are referring to.
Old   September 22, 2015, 15:46
AHF
AHF's Avatar
amirhossein
AHF is on a distinguished road
you use ansys fluent or fluent ?
which version ?
AHF is offline   Reply With Quote
Old   September 22, 2015, 15:59
Abayomi T. LAYENI
I am using ANSYS Fluent
Old   September 22, 2015, 16:47
Abayomi T. LAYENI
I am using ANSYS Fluent 14.5
Old   September 23, 2015, 16:24
AHF
AHF's Avatar
amirhossein
you can find reference value here in picture
when read mesh enable automatic
Old   September 23, 2015, 17:12
Abayomi T. LAYENI
Thanks AHF. Got it
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Calculate Average Nusselt number Reda.th Main CFD Forum 2 December 29, 2014 14:17
