ignore inner iteration in Transient mode
Like Tree2Likes
  • 1 Post By amin.z
  • 1 Post By amin.z
Old   August 28, 2015, 04:39
Default ignore inner iteration in Transient mode
Mina
Mina_Mbg is on a distinguished road
Hello verybody,
I am doing transient mode in Fluent and I would like to get the temperature for special point in each 1000 iteration .My time step is :1e-05,Max. Iteration per time step:25
and Number of time step: 3e+6
Te problem is iteration exceed the 3e+6 so I think the inner iteration (maximum 25) is also counted.
Does any body have the idea How can I set in a way that ignore this inner iteration to be printed?
If you need more detail for answering easily inform me.
thanks in advanced
Mina
Mina_Mbg is offline   Reply With Quote
Old   August 28, 2015, 05:34
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hi
what method are you using for getting the temperature?
Do you use monitor? if yes you can set it to print the temperature every time step instead of every iteration
If you use another method explain about it...
Mina_Mbg likes this.
amin.z is offline   Reply With Quote
Old   August 28, 2015, 05:54
Mina
yes excactly monotor point.
Then How can I clculate physical time step?I am doing it in HPC.
because I need to know the curve of Temperature for this point during 30Second.
Originally Posted by amin.z View Post
Hi
Old   August 28, 2015, 06:05
amin.z's Avatar
Amin
there is an option in the monitor settings as get data every
you can change the iteration to time step
fluent, iterations
Transient simulations: how to tell its converged (I've read the FAQ & user guides!) JuPa CFX 12 March 27, 2020 18:24
GPU - GeForce GTX Titan Black? frode86 Hardware 11 August 8, 2016 23:36
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
Transient flow in fluent linyx FLUENT 15 April 24, 2013 10:54
set temperature on subdomain, in transient mode nicolas CFX 0 August 16, 2006 07:42
