Nozzle force
Like Tree2Likes
  • 1 Post By LuckyTran
Old   August 25, 2015, 11:15
Default Nozzle force
MOHAMAD
MAMAD is on a distinguished road
Dear all
I have a simple question but i am a little confused!
I solved a simple internal flow of a converging nozzle and now i want to compute the force on the body. I calculate it in two ways
1- i used a control volume outside of nozzle (using pressure and momentum at inlet & outlet)
2- i used a CV inside the nozzle (Integrating pressure on walls)
But i got different answers i dont know why???
PLEASE help me !!!
MAMAD is offline   Reply With Quote
Old   August 25, 2015, 16:16
Lucky
This is a common mistake in CV analysis when trying to apply concepts learned from 1D control volumes in constant area ducts to non-constant area problems.
The only way to compute the force is to do a control volume analysis on the entire system, inlets & outlets & walls. You cannot do a control volume on only the inlet & outlet (those are only control surfaces). Likewise your control volume cannot only include the walls and not the inlet and outlet (still a control surface).
MAMAD likes this.
Old   August 25, 2015, 16:46
MOHAMAD
Dear Lucky Tran
Thanks for your response but i didn't get the point
what do you mean about non constant area? do you mean the 1D boundary assumption?
when i use the CV outside the nozzle, there is nothing on the nozzle acting except at control surfaces. we did this in fluid mechanics and there was nothing on walls!
i see the example in almost all fluid mechanic books!
what should i do? should i take into account pressure on body and momentum at in/outlet?
thank again!
Old   August 25, 2015, 18:09
Lucky
Sorry I got confused, thought you were trying to calculate thrust.
Integrating only the pressure only gives the pressure force and doesn't give you the viscous force. You need to include the wall shear stress also when you do the integration. Maybe that's the problem?
MAMAD likes this.
Old   August 26, 2015, 14:41
MOHAMAD
Dear LuckyTran
Viscose terms are not so big!!!
the flow is supersonic
i attached a figure which i mean about CV inside the nozzle.
Now if i use CV outside (think the dashed line is nozzle and the line is CV) there is no pressure on walls except ambient pressure which we can neglect it on the entire CV.
Thank you
control volume, nozzle flow
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
Force Acting on C-D Nozzle Walls Dimitri.H STAR-CCM+ 0 October 29, 2013 15:20
Force can not converge colopolo CFX 13 October 4, 2011 23:03
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 11:25
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
