Backflow direction specification method
Like Tree1Likes
  • 1 Post By LuckyTran
Old   August 5, 2015, 07:14
Default Backflow direction specification method
Fariz
mfim88 is on a distinguished road
1. Can anyone tell me when to use the option "from neighboring cell" and when not to? assuming we don't know initially whether backflow will occurs or not.
2. It is normal to have backflow when choosing "from neighboring cell" option and no backflow occurs when choosing "normal to boundary" option.
p/s: i am doing fluent simulation on a cyclone separator. (high swirling flow).
mfim88 is offline   Reply With Quote
Old   August 5, 2015, 14:31
Lucky
If the backflow direction is known, then you should specify it explicitly. If not known then there are two approaches:
The default is normal to the boundary where any back-flow will have a direction that is perpendicular/normal to the outlet boundary.
I am not sure of the specific calculation procedure, but when From Neighboring Cell is selected, the direction of the back-flow will be calculated based on the nearby cells. This means that the back-flow can enter at an angle with respect to the outlet boundary (it is not fixed to normal angles) but flow will be reversed in the sense of the local flow-field. This is useful when flow exiting the boundary is not normal to the boundary because of swirl, or you are trying to simulate compressor/fan discharge, etc.
nedanikou likes this.
Old   August 5, 2015, 21:45
Thumbs up
Fariz
ok thanks LuckyTran for the insight.
Yes, my case have high swirling at the outlet, thus, from what i understand, "from neighboring cell" will give more accurate results.
Old   September 23, 2017, 03:48
Default question
Neda S. R. Nikou
nedanikou is on a distinguished road
Hi
Would you please tell me how I can implement Neighboring Cell B.C. in code?
I wrote the outlet B.C. (pressure outlet B.C.- Neighboring Cell method) as follow:
Uxi(j,nz,i)=Uxi(j,nz-1,i)
Ueta(j,nz,i)=Ueta(j,nz-1,i)
Uzeta(j,nz,i)=Uzeta(j,nz-1,i)
i=1,nx
j=1,ny
k=1,nz
nedanikou is offline   Reply With Quote
backflow, direction, fluent, neighboring cell
Turbulence inflow generation - recycling method panda60 OpenFOAM Running, Solving & CFD 15 April 25, 2013 02:34
Turbulence Specification Method Srivatsan V. Rajagopalan FLUENT 5 January 31, 2011 07:39
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 12:31
Turbulence Specification Method for pressure outle co2 FLUENT 0 April 28, 2004 20:32
