July 27, 2015, 10:47 |
reference values for transient analysis
Ronald Thompson
Rep Power: 11 |
Im carrying out analysis on a vertical axis turbine in 2d, my turbine has three blades of 200 mm chord length the diameter of the turbine is 600 mm, I'm using a sliding mesh of diameter 800mm. I'm using a transition sst turbulence model. I have set up a monitor for Cm around the center of the aerofoils, but I am unsure as to what I have to set my reference values for Area, Depth and length I want to use these Cm to give me a Cp for my turbine. Any advice would be deeply appreciated and thanks in advance |
August 3, 2015, 16:51 |
david glynn
Rep Power: 11 |
Just wondering have you found a solution to this? as I find the reference values requirement confusing as well Thanks |
August 5, 2015, 06:41 |
Ronald Thompson
Rep Power: 11 |
Hi Davd,
I know as I'm doing my calculation in 2d depth should be left at 1m to make the rest pure unit length, as for the area I'm unsure whether this should be the area taken up the blades or the area taken up by the rotating mesh itself. and the same for the length should this be one of the diameters or radius of one of the above, I was thinking Radius of the Turbine as I'm looking for the Torque but Im unsure. Thanks |
coefficient of moment, reference -values, sliding interface, transient analysis, turbine blade |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 14:32 |
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 10:38 |
compile error about FJMPI | chiven | OpenFOAM Installation | 11 | March 31, 2010 07:27 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 01:34 |
