Difference in values of velocity contour and velocity vector
Like Tree1Likes
  • 1 Post By dreamz
Old   July 13, 2015, 14:36
Default Difference in values of velocity contour and velocity vector
Ashutosh
dreamz is on a distinguished road
I plotted a velocity contour and velocity vectors for a problem whose converged solution was obtained. I noticed that the values of the minimum and maximum values shown are different in both cases. I want to know what could be the possible reason? What is the exact value of minimum and maximum velocity in the domain?
Kindly help
jotac likes this.
Last edited by dreamz; July 14, 2015 at 01:13. Reason: Have to linkback an earlier post
dreamz is offline   Reply With Quote
Old   October 13, 2016, 22:50
lixuefang is on a distinguished road
Have you found the reason? I met the same problem recently.
lixuefang is offline   Reply With Quote
Old   October 17, 2016, 05:09
Zbynek is on a distinguished road
If you want to know the maximum and minimum of a quantity in a domain, just go to Report->Volume Integrals and choose Minimum/Maximum of the quantity. That's it.
As for the reason why the scale is different for vectors and contours - I do not know it but I guess that it may have something to do with the way how Fluent computes the auto-scale. This may be different for vectors and contours.
Zbynek is offline   Reply With Quote
Old   October 17, 2016, 05:43
Thank you, Zbynek. I know how to get the maximum and minimum values. I tried to export all the data on a surface to a ASCII file to see what the values were there, but failed to find out the reported max or min values. I am thinking about the Finite Volume Method that used in Fluent. Hope to find out how to calculate the values on node and facet center. If you have any idea, please let me know. You can get to me here or by email, lixfthu@hotmail.com
Old   October 17, 2016, 09:55
I am not sure I am answering any better now but - to get face values, use UDFs. You can simply use F_U to get x-velocity on a face, if you combine that with begin_f_loop(f,t), you can print the face values in a file and study the outputs.
Old   February 22, 2017, 07:43
Jose Carlos
jotac is on a distinguished road
Hi guys, I just found out why. From the Fluent User Manual: "toggles between using scalar field values at nodes and at cell centers for computing the contours. When the Filled option is off, Node Values is always on."
So basically the difference is due to the reference point you take info from. Hope it helps someone in the future
Cheers,
Jota
jotac is offline   Reply With Quote
contour, fluent, vector
velocity contour along an specific vector 1988 Tecplot 1 August 14, 2014 02:24
pressure contour and velocity profile problem alee1293 Main CFD Forum 0 July 18, 2014 11:31
Z velocity contour values differ from vectors ghost82 FLUENT 0 October 7, 2012 05:23
Display velocity vector and contour in the same window lalula2 FLUENT 2 August 24, 2009 09:11
Contour plot with negative velocity J CFX 11 November 3, 2008 17:46
