Fluent in Ansys Workbench : Change Working Directory
Like Tree3Likes
  • 3 Post By sral
Old   July 2, 2015, 12:24
Default [Closed] Fluent in Ansys Workbench : Change Working Directory
Lars
sral is on a distinguished road
I want to run a cfd analysis in Ansys Workbench V16.
Unfortunately, Ansys Workbench defines the Fluent workingdirectory as F: (which is a network accessed directory and therefore not suitable)
And I can't change it in this window. I changed the Ansys Workbench temporary directory:
But it has no effect on the Fluent job. It still writes to F: (it has more storage space than my HDD, maybe it is the selection criterion?)
The Ansys help is not useful:
When you start ANSYS FLUENT from either type of FLUENT-based system within Workbench, FLUENT Launcher will appear by default. Most FLUENT Launcher settings are available, except for the following options:
· Version (disabled)
· Working Directory (disabled)
· Use Journal File (not available)
I tried the following code in Fluent TUI, but it does not work (anymore in V16 ?!).
Originally Posted by devanson View Post
Hi macfly,
use this command to change dir in ANSYS Fluent environment through TUI command..
sync-chdir C:\a
One possible solution, which I will try tomorrow, is to unmount the network storage temporarily and start Ansys Workbench, which hopefully will select the desired D: drive alternatively.
But maybe you have a solution for this?
Thank you.
sral is offline   Reply With Quote
Old   July 3, 2015, 04:17
Lars
I unmounted the network drive and restarted Workbench. Now it chose the path
C:\Users\xxxxx\Desktop
and it stays that way, even if I remount the network drive.
But the Desktop is no suitable place for temporary files either. So the question stands.
Regards,
Lars
Old   July 3, 2015, 04:27
Lars
Now i found out:
It is dependent on where the ANSYS Workbench Shortcut is executed:
My default setting was %HOMEDRIVE%%HOMEPATH% which leads to the network drive.
I entered D:\temp\ansys and it works now.
Old   July 31, 2018, 03:08
majid
majid2546 is on a distinguished road
you should run the fluent from start menu and dont create project in workbench and dont run fluent inside of workbench
majid2546 is offline   Reply With Quote
Old   March 29, 2019, 11:29
ali
alinik is on a distinguished road
sral,
Did you solve it?
alinik is offline   Reply With Quote
directory, fluent, workbench, working
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 10:23
plotting temperature time graph using ansys workbench fluent Hithesh FLUENT 0 March 30, 2014 13:30
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
Ansys Workbench, Gambit and Fluent NK Main CFD Forum 0 January 22, 2009 10:25
