absorption and scattering coefficient of air for DO model |
June 1, 2015, 05:37 |
Charlie d'hondt
I'm working on heat transfer problem , I simulate a test room and I put an electrical radiator. I want to see effect of radiation heat transfer in my room. So I use Discrete ordinate model becaus I want air medium but I don't have absorption and scattering coefficient of air. I'm looking for this data but I don't find it anywhere. May someone have an idea of these two properties of air ? I want these properties for temperature between 0 and 100°C and in infrared radiation. Thank you |
June 28, 2015, 12:04 |
#2 | |
Siyang Hu
You didn't give more details about your case. So, I supposed that you just use a radiator to heat up the air in the room and then figure out the warm (or buoyant flow?) air flow indoor. Am I right? If so, in my personal opinion, I would like to set these two properties to ZERO as the air (if does not contains additional greenhouse gases or particles) is almost transparent to the IR radiation. I think your case may be similar to the greenhouse process. But for a 'pure' air, its temperature is mainly increased by the thermal convection of the surface of the room but not the radiation absorption of it. For a better interpretation, u can find the fundamental definition of greenhouse effect on Wikipedia. My solution mentioned above is based on it actually. Good luck! Ray |
February 3, 2017, 14:27 |
#3 | |
ss
Rep Power: 10 |
February 6, 2017, 00:38 |
Lucky
Rep Power: 66 |
2 things!
1) Try looking for absorptivity instead of absorption coefficient. Absorption coefficient can then be estimated from Beer-Lambert law if you can come up with the length scale. Absorption coefficient is path dependent and includes geometry effects so it is not purely a property of the substance. Hence why is is very hard to find, because it is specific to each problem and not worth reporting, whereas absorptivity is a material property. 2) It is indeed difficult to find these properties. Try looking for properties of water vapor or wet air (not dry air). Air is primarily nitrogen and oxygen (then some trace amounts of He and Ag), which are pretty much transparent to infra-red because they're all straight molecules. The primary participating media are the bent molecules, CO2 and H2O, which we normally don't include in the definition of dry-air! Btw it is extremely difficult to find these properties over a range of temperatures. You will likely end up with only the properties at room temperature or something like that. Most of these properties were measured back in the old days. My undergrad heat transfer textbook (Incropera and Dewitt) has these graphs. |
July 5, 2020, 08:35 |
#5 | |
Himanshu
Rep Power: 9 |
when you are saying "(if does not contains additional greenhouse gases or particles)" ,does this mean if the air does not contain CO2 more than naturally it has? |
absorption coefficient, air, do model, scattering coefficient |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
