Closed Domain: Velocity Problem
Like Tree1Likes
  • 1 Post By malpoli247
Old   May 7, 2015, 08:00
Default Closed Domain: Velocity Problem
malpoli247 is on a distinguished road
Hey there,
I am modeling a raceway pond and have a question regarding the velocity/ the drive.
My model is currently a 2D Model. The best way to describe it is the attatched picture.
Now, I wonder how I model the paddlewheel best. I thought of modeling it with a UFD, because i dont think there is a appropiate boundery condition for it...
Can you guys help me ?
My thanks in advance!
malpoli247 is offline   Reply With Quote
Old   May 7, 2015, 08:50
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi think the best way is modeling with VOF (air + water).
You can use MRF or mesh motion, by splitting the domain into 2 parts (rotor, enclosing the impeller and stator).
If you use MRF there's no need to use udf, just set a frame motion and input directly the rotational velocity; if you use mesh motion you can directly input the rotational velocity, but if you start your simulation with water at rest you may need to slowly increase the impeller rotational velocity till reaching the final one (you can write a DEFINE_CG_MOTION udf and increase rotational velocity linearly with time, for example, from 0 rpm till xx rpm).
If you use mesh motion you need to create interface between rotor and stator, no need to create interface with MRF.
Or you can create interface, starting with a MRF solution and then switch to mesh motion.
Daniele
PS: if you want to simulate the domain you posted in the picture you have to make a 3d simulation
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   May 8, 2015, 06:02
Hey,
thank you for your answer. I will try as you suggested!
Sure i know that i will need 3d for the whole model, but i wanted to try the drive with a 2D model...
Now i will do it in 3D
Tank You
p.s.
if anyone ever finds this in search or google, try this tutorial for MRF
https://www.youtube.com/watch?v=P2vaj70ATZs
andresdete likes this.
boundery, closed domain, raceway pond, udf
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
injection problem Mark New FLUENT 0 August 4, 2013 02:30
[snappyHexMesh] solve a single domain problem nandiganavishal OpenFOAM Meshing & Mesh Conversion 0 July 8, 2013 12:36
velocity problem phy FLUENT 1 February 8, 2008 18:12
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 12:21
