External aerodynamics of an aircraft: pressure based solver or density based solver?
Like Tree1Likes
  • 1 Post By gdbb89
Old   April 29, 2015, 12:00
Default External aerodynamics of an aircraft: pressure based solver or density based solver?
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Hello guys;
Can any one tell me if it will be okay to use pressure based solver to simulate an external flow past an aircraft at M = 0.85 and Re = 5 million? or is density based solver a must?
Also; When setting reference values such as reference area and length I have put the Sref of the wing as 383 m2 and ref length as the reference chord length 7m? is this the standard way. Please help me and share any views. I have been having trouble with this for a while.
shereez234 is offline   Reply With Quote
Old   April 30, 2015, 14:33
gdbb89 is on a distinguished road
Compressible effects need to be accounted for once you exceed M = 0.3. I would highly suggest a density-based solver. Chord length should be your reference length (you are solving for wall shear/drag, yes?), and the planform area should be your reference area (integrating wall shear along this area for total skin friction drag).
shereez234 likes this.
gdbb89 is offline   Reply With Quote
Old   April 30, 2015, 16:30
shereez234's Avatar
M Sereez
Thanks for the reply. One more question:
What do you think is a reasonable mesh size to get an accurate drag?
Would 5-8 million elements be reasonable?
Pressure based and Density based Solver Xobile Main CFD Forum 39 August 19, 2020 07:04
Can't get data from OpenFoam to external solver using externalCoupled perry OpenFOAM Running, Solving & CFD 4 May 26, 2014 09:09
Acoustic waves in pressure based solver michujo Main CFD Forum 1 October 19, 2013 04:52
Regarding Density based solver Eswar Main CFD Forum 2 June 6, 2007 12:00
Density based solver Eswar Main CFD Forum 2 May 29, 2007 08:29
