Error in compute process - No Active Application
Like Tree1Likes
  • 1 Post By iancmlositano
Old   April 27, 2015, 15:04
Default Error in compute process - No Active Application
Yetly
yetlyg is on a distinguished road
Hello and Good day to all,
For my computation, I am using a research license at school. I ran fluent with Parallel Run Settings and used "4" as the number of processors. I let my computation run over the weekend and I get the following messages (Please see below)
After reading a couple of threads, I am noticing that my problem might be with the license server. I also noticed that in Workbench, I see a message that says "License server lost for 5 min" "License server will time out if not reconnected".
Can anyone recommend how I can continue my computation? Would I need to contact the school administrator? I click calculation again, and the window shows a message "There is no active application".
Thank you very much.
754821 2.8192e-03 1.1893e-07 2.7115e-07 9.2632e-13 5.8923e+02 -5.8174e+03 5.8953e-04 0:00:18 62
754822 1.7209e-03 1.0489e-07 2.3739e-07 1.6337e-13 5.8923e+02 -5.8174e+03 5.8953e-04 0:00:27 61
!754823 solution is converged
754823 8.1369e-04 7.2405e-08 2.1197e-07 7.3824e-14 5.8923e+02 -5.8174e+03 5.8953e-04 0:00:21 60
(ani-monitor-update 3 #t #f)()
(ani-monitor-update 2 #t #f)()
(ani-monitor-update 1 #t #f)()
Writing "C:\Senior Project 2015\Senior Project\ANSYS\TES_A2_files\dp0\FFF\Fluent\FFF-Setup-Output-26-0-31.780.000.cas"...
1280 quadrilateral cells, zone 5, binary.
9600 quadrilateral cells, zone 6, binary.
1280 cell partition ids, zone 5, 4 partitions, binary.
9600 cell partition ids, zone 6, 4 partitions, binary.
2400 2D interior faces, zone 1, binary.
19120 2D interior faces, zone 2, binary.
160 2D wall faces, zone 4, binary.
160 2D wall faces, zone 7, binary.
160 2D wall faces, zone 8, binary.
160 shadow face pairs, binary.
11121 nodes, binary.
11121 node flags, binary.
Done.
Error: Out of Scheme heap space.
Rerun with -h flag set greater than current value of -h100000
Error encountered in critical code section
MPI Application rank 0 exited before MPI_Finalize() with status 1
===============Message from the Cortex Process================================
Fatal error in one of the compute processes.
Error: There is no active application.
Error Object: (case-modified?)
Error Object: (data-valid?)
Error Object: (%show-case-id)
yetlyg is offline   Reply With Quote
Old   July 15, 2016, 14:21
Airede Yusuf
YusufAirede is on a distinguished road
I am currently having the same issues at my university
YusufAirede is offline   Reply With Quote
Old   April 18, 2017, 05:36
puneet
puneet336 is on a distinguished road
Were you able to fix the error?
If yes, then could you please share the resolution ?
Done.
puneet336 is offline   Reply With Quote
Old   May 18, 2017, 21:45
Unhappy MPI error
Ian Carlo M. Lositaņo
iancmlositano is on a distinguished road
I am having issues with MPI too. It seems when the connection to the Internet is cut, the calculation using parallel computing ends as well. Here is the last message error in the task page:
Updating solution at time level N... done.
iter continuity x-velocity y-velocity k omega time/iter
63480 3.0371e-06 7.3886e-08 5.8098e-08 8.9681e-09 2.7776e-07 0:00:08 20
63481 2.6566e-04 3.9779e-05 3.5085e-05 4.1178e-04 3.9897e-04 0:00:10 19
63482 3.5328e-04 3.4743e-05 3.1314e-05 9.0807e-05 1.4068e-04 0:00:11 18
63483 1.8082e-04 7.4258e-06 6.6235e-06 2.1359e-05 5.5892e-05 0:00:08 17
63484 1.1755e-04 8.2641e-06 7.0098e-06 5.6698e-06 2.5103e-05 0:00:10 16
63485 9.1789e-05 6.3230e-06 5.6392e-06 1.8238e-06 1.2752e-05 0:00:07 15
63486 7.6213e-05 4.4365e-06 4.1172e-06 7.4165e-07 7.2741e-06 0:00:08 14
63487 6.3138e-05 2.8474e-06 2.6977e-06 3.7283e-07 4.6117e-06 0:00:06 13
63488 5.1390e-05 1.8470e-06 1.7832e-06 2.1825e-07 3.1803e-06 0:00:07 12
63489 4.1426e-05 1.1609e-06 1.1324e-06 1.4063e-07 2.3284e-06 0:00:05 11
63490 3.2853e-05 7.6994e-07 7.5898e-07 9.6510e-08 1.7749e-06 0:00:06 10
63491 2.6075e-05 5.8871e-07 5.6553e-07 6.9219e-08 1.3920e-06 0:00:04 9
63492 2.0678e-05 4.5819e-07 4.2269e-07 5.1370e-08 1.1151e-06 0:00:04 8
63493 1.6355e-05 3.6067e-07 3.1704e-07 3.9208e-08 9.0925e-07 0:00:03 7
63494 1.2814e-05 2.4193e-07 2.1392e-07 3.0453e-08 7.5200e-07 0:00:03 6
63495 1.0001e-05 1.8607e-07 1.5998e-07 2.4193e-08 6.2847e-07 0:00:02 5
63496 7.9209e-06 2.1126e-07 1.5731e-07 1.9473e-08 5.2924e-07 0:00:02 4
63497 6.2813e-06 1.5717e-07 1.0939e-07 1.5784e-08 4.4865e-07 0:00:01 3
63498 4.9718e-06 1.2919e-07 8.3865e-08 1.2937e-08 3.8147e-07 0:00:01 2
63499 3.9602e-06 1.0712e-07 6.6367e-08 1.0764e-08 3.2589e-07 0:00:00 1
63500 3.1854e-06 1.1955e-07 6.6387e-08 8.9968e-09 2.7702e-07 0:00:00 0
Writing "| gzip -2cf > C:\Users\Ian Carlo\OneDrive\Documents\Ian Carlo\Intellectual\Academic\Thesis\Data\Run11.1_VA WT6_files\dp0\FFF\Fluent\VAWT6f-3-03175.cas.gz"...
Writing temporary file C:\Users\IANCAR~1\AppData\Local\Temp\flntgz-315121272 ...
17988 triangular cells, zone 2, binary.
50270 mixed cells, zone 8, binary.
17988 cell partition ids, zone 2, 4 partitions, binary.
50270 cell partition ids, zone 8, 4 partitions, binary.
26667 2D interior faces, zone 3, binary.
84139 2D interior faces, zone 9, binary.
628 mixed interior faces, zone 18, binary.
158 2D wall faces, zone 7, binary.
208 2D wall faces, zone 11, binary.
208 2D wall faces, zone 12, binary.
208 2D wall faces, zone 13, binary.
314 2D wall faces, zone 14, binary.
79 2D pressure-outlet faces, zone 6, binary.
79 2D velocity-inlet faces, zone 5, binary.
314 2D interface faces, zone 4, binary.
314 2D interface faces, zone 10, binary.
628 interior parent pointers, zone 18, binary.
628 interface metric data, zone 18, binary.
44427 nodes, binary.
44427 node flags, binary.
999999: mpt_connect: error: connect failed: No error
999999: mpt_establish_connection: error: unable to connect: No error
0: mpt_connect: error: connect failed: No error
1: mpt_connect: error: connect failed: No error
2: mpt_connect: error: connect failed: No error
3: mpt_connect: error: connect failed: No error
3: mpt_establish_connection: error: unable to connect: No error
1: mpt_establish_connection: error: unable to connect: No error
2: mpt_establish_connection: error: unable to connect: No error
0: mpt_establish_connection: error: unable to connect: No error
999999: mpt_accept1: warning: accept failed
RPC CX_Flush failed.
: RPC: Unable to receiveError 10054,
0: mpt_accept1: warning: accept failed
1: mpt_accept1: warning: accept failed
3: mpt_accept1: warning: accept failed
2: mpt_accept1: warning: accept failed
Error: Error writing "| gzip -2cf > C:\Users\Ian Carlo\OneDrive\Documents\Ian Carlo\Intellectual\Academic\Thesis\Data\Run11.1_VA WT6_files\dp0\FFF\Fluent\VAWT6f-3-03175.cas.gz".
Error Object: #f
MPI Application rank 0 exited before MPI_Finalize() with status -1
Error:
C:\PROGRA~1\ANSYSI~1\v150\fluent\fluent15.0.7\cort ex\win64\cx1507.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
iancmlositano is offline   Reply With Quote
Old   May 18, 2017, 21:46
Default MPI error
Does anyone here know of a workaround to this Fluent error with the local processor? I am using Intel by the way. I have been trying to understand this for more than a week already.
Old   July 5, 2017, 08:04
I've worked this out. When running Ansys Fluent parallel processing, the software should be able to detect a network connection for the MPI to be validated. Even if there is no active Internet connection as long as it is stable and not fluctuating, the run/simulation will continue. I've encountered the same many times already and this recourse has helped me run the calculation continuously.
Sent from my HUAWEI TIT-U02 using CFD Online Forum mobile app
Gang Shen likes this.
Old   April 23, 2018, 02:22
Gang Shen
Gang Shen is on a distinguished road
Hi iancmlositano, Could you please give more detailed information to resolve this issue? Many thanks!
Gang Shen is offline   Reply With Quote
Old   October 18, 2018, 22:20
Default Problem solution: h flag
Celso Murilo
CelsoMurilo is on a distinguished road
I had the same problem, but after a long simulation time.
In my case, I was able to solve it like this:
Write case and data.
New initialization (again), restarting all variables.
Run a few timesteps
Import old archived ".dat".
Saving new cas and dates
Run normally
CelsoMurilo is offline   Reply With Quote
Old   October 27, 2018, 23:30
Thumbs up
Gang Shen
Thanks, CelsoMurilo. Good idea. It is worthy to try in the future.
Run a few timesteps
Run normally
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 18:08
application of active flow techniques on rotating eva Main CFD Forum 1 August 16, 2003 09:48
