How to determine viscous resistance and inertial resistance porous media |
April 15, 2015, 15:37 |
Djilali
I can't understand how i can enter these coeffiecents please look at the picture and i work with cavites porous media ----- please i wanna your help my problem is simulation enclosure porous media and i dont what does mean these coefficients look at the picture this is the attached picture... thanks Djilali Last edited by wyldckat; April 18, 2015 at 16:17. Reason: merged posts since they were on the same topic |
April 18, 2015, 16:42 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: Have tried clicking on the "Help" button?
I say this because the documentation provided by the application should explain what all of those parameters are, and how they should be calculated. |
April 18, 2015, 17:13 |
#3 | |
Djilali
help doesn't work if you knows any things about it plz help me |
April 18, 2015, 17:47 |
Bruno Santos
Rep Power: 128 |
I did just now a quick search with Google for
CFD porous media
I then searched for: Code:
fluent "porous zone" direction-1 Everything you're asking for seems to be explained on that page. Good luck! |
April 18, 2015, 17:50 |
#5 | |
Djilali
Last edited by wyldckat; April 18, 2015 at 18:13. Reason: Added proper [QUOTE] markers |
April 18, 2015, 18:14 |
#6 | |
Bruno Santos
Rep Power: 128 |
As I wrote before, everything is explained on this page:
April 18, 2015, 18:34 |
Djilali
April 18, 2015, 19:28 |
Inertial Losses in Porous Media????????????????
#8 | ||
Djilali
April 19, 2015, 12:04 |
#9 | |
Bruno Santos
Rep Power: 128 |
fluent porous c2 |
April 20, 2015, 08:07 |
hey Bruno Santos
#10 |
Djilali
hey Bruno Santos
i wanna ask you why we puts the values of viscous and inertial Resistances in direction-1 bigger than direction 2 i work with 2D and should i put the same way? and i work on heat transfer in enclosure porous media one side is has temperature heat the red one and other has temperature cold the blue one and the walls orizontale are adabatic. as you know my assumptions the medium is homogenous and isotropic look at the picture you will understand what i mean please bruno help me thank you for everything you did with me before Djilali Which method suitable for my problem to derive viscous and inertial loss coefficients? 1. Method: Deriving Porous Media Inputs Based on Superficial Velocity, Using a known Pressure Loss. 2.Method: Using the Ergun Equation to Derive Porous Media Inputs for a Packed Bed 3.Method: Using an Empirical Equation to Derive Porous Media Inputs for Turbulent Flow Through a Perforated Plate. Well my model is 2d and i have flow in both directions. why that the viscous and inertial resistance in the y-direction is 10 times larger than that in the x-direction.so does this mean that I have to set X=0.1 and Y=1 Last edited by djodjo; April 20, 2015 at 09:37. |
April 26, 2015, 15:31 |
#11 | |||
Bruno Santos
Rep Power: 128 |
Hi Djilali,
I don't know what you should do in this case. It seems to me that you should ask for more details from whomever gave you this task. Good luck! Best regards, Bruno |
April 26, 2015, 18:58 |
#12 | |
Djilali
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 8 | May 30, 2024 03:59 |
How to define the porous inertial resistance and viscous resistance of porous media? | pinfan143 | STAR-CCM+ | 5 | July 21, 2015 12:52 |
Viscous and Inertial Resistance in Porous Media | aulu | FLUENT | 0 | September 14, 2011 06:21 |
Porous Media Inertial and Resistance | giogio | FLUENT | 3 | June 21, 2011 19:09 |
how to calculate the viscous and inertial resistance coefficients? | omurakbayir | FLUENT | 1 | November 22, 2010 23:36 |
