April 17, 2015, 13:00 |
NOx Postprocessing
Hi, I'm newbie with Fluent.
I'm studying a CO/H2-Air burner and I'm trying to calculate prompt and thermal NOx. The following values have been used in calculating the mixture fraction: Total Mass fraction of Oxygen atoms in the air stream, Zo,o = 0.233 Total Mass fraction of Carbon atoms in the air stream, Zc,o = 0.0 Total Mass fraction of Hydrogen atoms in the air stream, Zh,o = 0.0 Total Mass fraction of Oxygen atoms in the fuel stream, Zo,f = 0.4995 Total Mass fraction of Carbon atoms in the fuel stream, Zc,f = 0.3746 Total Mass fraction of Hydrogen atoms in the fuel stream, Zh,f = 0.1259 I would like to know how to calculate fuel carbon number and equivalence ratio. In Ansys help, I read that fuel carbon number is the number of carbon atoms in a fuel molecule but I have two species in my fuel. How should I do? Equivalence ratio is given by actual "fuel-air-ratio" and stoichiometric "fuel-air-ratio" but I have a burner with not defined mass of injected air. I don't know how to calculate it. Help me please. I'm sorry for my bad english but I'm italian. Thank you a lot for every answer! |
April 20, 2015, 04:36 |
Some help please?
June 12, 2017, 09:24 |
Manina Sabi
Rep Power: 9 |
August 1, 2017, 11:19 |
Rep Power: 10 |
Fuel carbon number is the total number of carbon atoms in the fuel. For example your fuel has 90% CH4, 7% C2H6 and 3% C3H8; then your fuel carbon number is:
0,9*1 + 0,07*2 + 0,03*3 = 1,13 Equivalance ratio is = 1/lambda = 1/(1+%O2/(21-%O2)) If your O2% is 3,5% then: equivalance ratio is 0,8333 |
nox |
using fieldAverage library to average postprocessing | eelcovv | OpenFOAM Programming & Development | 32 | May 17, 2022 10:55 |
Fluent NOx model | Allan Walsh | FLUENT | 1 | June 21, 2013 06:06 |
Nox modelling | igorb | FLUENT | 0 | June 17, 2011 07:28 |
fluent nox module for nox reduction using sncr | asim ibrahim | Main CFD Forum | 3 | October 11, 2006 03:07 |
NOx postprocessing with CFX-TASCflow 2.11 | Luca | CFX | 1 | October 17, 2002 00:58 |
