April 4, 2015, 23:19 |
Exact reference values for a 2D airfoil
Mahdi
Rep Power: 14 |
Hi there
I'm going to calculate the drag, lift and moment coefficient of an airfoil in 2D case. I've got good mesh and pressure and lift coefficients obtained from primary runs have good agreement with my experiments. But there is a big difference in drag coefficient. I found that with changing the values in reference values the calculated force coefficients will be changed. but I'm not sure for an airfoil with these dimensions which values are appropriate. Chord=0.7 (m) Max thickness=0.14687 (m) Span=0.5 (m) (the airfoil used in experiments) Any help is most welcome. |
areas, depth, length, reference values |
wmake problems during custom utility compilation | palazi88 | OpenFOAM Programming & Development | 11 | August 13, 2018 21:52 |
reference values - 2D airfoil model | ANDRES ORTIZ | FLUENT | 6 | April 1, 2015 19:33 |
problem with turbulence models after compilation? | lfgmarc | OpenFOAM Programming & Development | 19 | November 20, 2013 01:50 |
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 10:38 |
[Commercial meshers] Conversion form .ccm to openFoam | ViktoriaE | OpenFOAM Meshing & Mesh Conversion | 1 | November 29, 2011 17:40 |
