March 31, 2015, 18:35 |
problem
Radwanma
Rep Power: 12 |
Hi all,
I have this problem when I have done solution in Fluent but I can not solve it " WARNING: Limited wall distance for 28 cells to 1.000000e-12. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm. iter continuity x-velocity y-velocity z-velocity k omega Cl-aerofoil Cd-aerofoil time/iter # Divergence detected in AMG solver: x-momentum -> Increasing relaxation sweeps! |
April 1, 2015, 09:40 |
Rep Power: 12 |
I had this kind of warning a while ago when simulating nozzle flow with an y+ < 1 mesh. In my case the cell wall distance in the first cell layer near the wall was not correct, it got bigger, than smaller than bigger and so on, when it only should get smaller.
In my case I meshed the region with a different method with the ANSYS mesher and the problem was solved. I suspect this happens, when the mesh accuracy has to be very high. You can visualize the cell wall distance as stated in the warning message to see if it is the same problem in your case. |
March 31, 2016, 17:50 |
using TUI
h
--write in command screen--
solve (press enter) initialize (press enter) repair |
April 1, 2016, 14:06 |
Lucky
Rep Power: 66 |
It's likely a meshing problem. You have cells that are much smaller than the minimum threshold for the distance to the nearest wall. This can be caused by skewed cells or you have very very very small cells next to walls in your mesh.
Note that 1e-12 m is 1 pm, which is a sub-atomic length scale and there is no reason to be doing CFD (fluids) at that length scale. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
