Turbulent Dispersion model in multiphase
Like Tree3Likes
  • 2 Post By amin.z
  • 1 Post By vinerm
Old   March 10, 2015, 16:29
Cool Turbulent Dispersion model in multiphase
amin.z's Avatar
Amin
amin.z is on a distinguished road
hey friends
I have a question about turbulent of multiphase flows!
I'm modeling a bubbly flow and I'm using Eulerian multiphase!
the problem is about turbulent modeling!
In interaction tab, there is a tab as "Turbulent Dispersion" and we have these 3 choices:
1.none
2. Lopez de Bertodano
3. Simonin
4. Burns et al
5. Diffusion in vof
6. UDF
in your idea which model is better for my problem?
Thanks in advance!
amin.z is offline   Reply With Quote
Old   March 11, 2015, 12:46
amin.z's Avatar
Amin
Any idea?
for which model, each of them is appropriate?
Old   July 13, 2016, 12:50
P_VS is on a distinguished road
Hello!
I just have the same doubt. What did you finally choose?
P_VS is offline   Reply With Quote
Old   July 14, 2016, 02:18
amin.z's Avatar
Amin
It was a long time ago, but here is what I found:
1. According to my personal communications with Dr. Bertodano, his model is very old and the coefficient of the model is completely arbitrary. He recommended me to use other available models.
2. According to my personal communications with Dr. Burns, his model could be taken advantage for low Stokes number flows, which is almost always the case for bubbly flow, in view of their small relaxation time scale. The Simonin model should also be applicable, and should give virtually the same results as FAD in this limit. The FAD model is less applicable for high Stokes number flows, for example large solid particles and drops, for which the Simonin model would be better.
Unfortunately I didn't find any reliable references about the rest of the models.
BlnPhoenix and P_VS like this.
Old   July 14, 2016, 09:52
Thank you very much!
As you say, It is not easy to find references about this.
I really appreciate your help
Old   January 4, 2020, 08:06
Mel B
Mel B is on a distinguished road
Hi! Options include -none- for turbulence dispersion force.
What does this mean if we select -none- option?
Mel B is offline   Reply With Quote
Old   April 15, 2020, 19:09
Min Zhang
minzhang is on a distinguished road
1. Low Stokes number flows, I am wondering how low is low? 0.1 is low?
2. The Simonin model is applicable for both low and high Stokes number?
3. What is FAD here?
Thanks!
Originally Posted by amin.z View Post
minzhang is offline   Reply With Quote
Old   April 15, 2020, 19:11
Min Zhang
I am wondering whether you have an answer now?
Thanks!
Old   April 16, 2020, 05:54
Default The answers
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
To get answers to these questions, it is better to go through their relevant articles.
None is just none; no model applied, i.e., no turbulent dispersion included. It's user choice, of course. Low Stokes number means lower than even 0.1, usually an order of magnitude lesser but even 0.1 can be considered low. FAD means Favre Averaged Drag model, based on Burns et al. work.
A. D. B. Burns, et al. The Favre Averaged Drag Model for Turbulent Dispersion in Eulerian Multi-Phase Flows
O. Simonin and P. L. Viollet. Modeling of Turbulent Two-Phase Jets Loaded with Discrete Particles
J. O. Hinze. Turbulence
minzhang likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 23, 2020, 06:10
geth03 is on a distinguished road
geth03 is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
Simulation multiphase airlift reactor with Eulerian multiphase model question???? dilok.kumyoo FLUENT 0 January 28, 2015 03:15
Turbulent Boundary Layer and Chase Model Kossivi System Analysis 0 November 16, 2014 00:49
Bubble column, multiphase model wprostaff FLUENT 0 July 11, 2011 09:02
Selecting the appropriate multiphase model and radiation model panos_metal FLUENT 0 June 18, 2010 08:58
