Loading UDF whithout libudf?
Like Tree2Likes
  • 1 Post By pakk
  • 1 Post By pakk
Old   February 22, 2015, 04:39
Default Loading UDF whithout libudf?
mahdi
mahdi_izadi is on a distinguished road
Dear colleagues
I have compiled a UDF in my case in serial mode, and then save it after some iteration and use it for parallel running.
The libudf folder has deleted.
Although All UDF equations are truly working but at reading case, It says auto compilation skipped no libudf found.
can it cause error?
regards
mahdi_izadi is offline   Reply With Quote
Old   February 23, 2015, 09:53
pakk will become famous soon enough
Yes it can cause big errors, your user defined function no longer work.
If you say "all UDF equations are truly working", I wonder what you mean. Fluent has no way to know which UDF equations you should have, so nothing should work.
mahdi_izadi likes this.
pakk is offline   Reply With Quote
Old   February 23, 2015, 11:37
mahdi
Dear Friend, pakk
Thanks for your answer.
udf includes 4 reaction.I mean reactions are happening, their heat of reaction and products are appearing(You mean the answer of product and Heat may change with or whitout LIBUDF-although it is getting solved)
I expect an equation to be or not to be! but changing with removal of UDF seems peculiar.
In fact I just have problem with interpolating mass fraction of species for changing mesh!
Regards
Old   February 23, 2015, 12:42
I believe you that your reactions are happening in the simulation. But I don't think any UDFs are used for the properties of those reactions.
I don't know which macro was in your udf, but possibly it was "DEFINE_VR_RATE". If you removed your udf, the equations in "DEFINE_VR_RATE" are not used, but Fluent uses the simpler constant rates. You will not see this as an extra warning or error, but you will just get wrong results.
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 16:47
UDF loading issues xinquanzhoucn Fluent UDF and Scheme Programming 1 February 10, 2013 19:53
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
