Improve Orthogonal Quality within Fluent
Like Tree1Likes
  • 1 Post By ptstorey
Old   February 14, 2015, 11:04
Default Improve Orthogonal Quality within Fluent
Peter Storey
ptstorey is on a distinguished road
I've done some shape optimisation (with adjoint solver) and the orthogonal quality has dropped from higher than 0.9 down to 0.5, and I'm beginning to see signs that the solution is struggling to converge.
What is the best way to refine/ improve orthogonal quality of the mesh?
So far I have tried Mesh > Smooth/Swap which has made it better, but I don't really know what I'm doing.
Thanks!
Vinay94 likes this.
ptstorey is offline   Reply With Quote
Old   February 15, 2015, 12:16
Tanmay Inamdar
Tanmay95 is on a distinguished road
It will be better if you can do it in your mesher.Using a finer mesh helps.
Tanmay95 is offline   Reply With Quote
Old   February 16, 2015, 03:37
maverick123 is on a distinguished road
Read mesh in Fluent mesher. Use mesh/tool/auto-node-move command.
You can give a try with various dihedral angles.
Thanks!
maverick123 is offline   Reply With Quote
Old   February 16, 2015, 09:51
Peter Storey
My mesh is pretty fine already. My problem is that I can't take my .msh file back across to ICEM-CFD... unless you know a way of doing it?
Originally Posted by maverick123 View Post
I haven't used Fluent mesher before, is it accessible from the Fluent main window?
Thanks for you replies
Old   February 17, 2015, 03:22
While launching Fluent standalone (not through WB) you can find toggle to launch in Meshing Mode.
Old   February 17, 2015, 07:25
Peter Storey
Ah I see. I'm currently working in 2D, and meshing mode isn't an option when selecting 2D. Is there a way around this?
Thanks
Old   February 19, 2015, 06:00
You can not modify 2D mesh in fluent meshing.
Thanks
Old   June 24, 2015, 09:54
revilo82 is on a distinguished road
I think the ortho quality (>0.1) is ok for CFD and Adjoint. After some optimization loops not only the mesh changed but the flow situation, too. That (could be) the reason for convergence issues. The question is, how does the "solution is struggling to converge"? Does it diverge, oscillate, do you see some instabilities, slow convergence, ... ?
revilo82 is offline   Reply With Quote
Old   August 3, 2015, 13:57
prafulla145 is on a distinguished road
orthogonal quality close to 1 is good, first try with default max face area, max and min sizing setting.If not then with trial and error obtain orthogonal quality close to 1. Orthogonal quality less than 0.001 is very poor.
prafulla145 is offline   Reply With Quote
[ICEM] Tips on how to improve the quality of this mesh crimsoncabbages ANSYS Meshing & Geometry 0 September 12, 2014 07:26
[Other] Using mesquiteMotionSolver to improve mesh quality. icaroaccordi OpenFOAM Meshing & Mesh Conversion 0 August 6, 2014 09:59
Mesh quality and wall function in FLUENT - k-omega model newcomer ANSYS Meshing & Geometry 1 May 19, 2011 04:00
Improve smoothness & quality of structured grid quarkz Main CFD Forum 2 March 10, 2007 16:26
High Quality Image from Fluent Mike FLUENT 4 September 7, 2005 08:41
