January 20, 2015, 09:28 |
Unable to create Periodic Boundary in Fluent
Rep Power: 11 |
Hello everyone, I am working on a project in which I have to model a flow pattern through a 1-D Rhombohedral unit cell(picture attached).
In the fig.,fluid enters the unit cell from the lower face and flows in the +y direction. I need to make the 2 opposite faces periodic(marked as yellow faces). I have tried to do this by typing the following command in the TUI of Fluent: mesh-->modify-zones-->mp Periodic zone [()] 7 Shadow zone [()] 9 Rotational periodicity? (if no, translational) [yes] n Create periodic zones? [yes] y Auto detect translational vector? [yes] y computed translation deltas: -0.028085 -0.000148 -0.000000 zone 7: matched 0 out of 478 faces. zone 9: matched 0 out of 478 faces. Error: Failed to make zones periodic. Error Object: #f What do I do? Is there a way I can make meshing in the 2 faces identical in Workbench Meshing itself? Any help will be much appreciated. Thanks in advance.. |
January 20, 2015, 09:32 |
Rep Power: 11 |
are you on serial or parallel mode? I'm not shure but try to open fluent in serial mode when you want to set periodic conditions..
January 20, 2015, 09:35 |
Rep Power: 11 |
Thanks for your reply.. I am not sure about the mode whether serial or parallel. Where can we know that?
January 20, 2015, 09:42 |
Rep Power: 11 |
normally the window title should be "<case name> parallel_if_parallel Fluent@<computer name> [<parameters>]"
otherwise relaunch Fluent and check the voice "processing optinos" on the launcher |
January 20, 2015, 09:50 |
Rep Power: 11 |
Btw, just found that the mode is serial (written in Fluent Launcher)
January 20, 2015, 09:55 |
Rep Power: 11 |
ok, it is not the source of the problem sorry but my help can't go further
good luck! |
January 20, 2015, 09:59 |
Rep Power: 11 |
@philus, no problem mate
March 2, 2015, 20:13 |
Hey,
Are you able to do this in fluent? I'm having the same problem. Regards Tharanga |
March 3, 2015, 04:52 |
#9 |
Rep Power: 11 |
@Tharanga, sorry mate...haven't found a solution yet
March 3, 2015, 05:26 |
#10 |
Rep Power: 12 |
@ Convoy
Have you tried non-conformal periodic interfaces? For that you need to change the zone-type of these 2 face zones to interface. |
March 3, 2015, 14:35 |
#11 |
Rep Power: 11 |
@maverick123, yeah I did try making the two surfaces as interfaces and applying non-conformal periodic boundary condition. But on doing that, when I tried to make the two interfaces periodic by going to the "Mesh Interface" window, I didn't know what Offset value I should take. When I assumed the Offset as (0,0,0) I got the error message "Couldn't intersect threads 7 and 9". 7 and 9 are the zone IDs.
March 4, 2015, 03:16 |
#12 |
Rep Power: 12 |
@Convoy
You are using wrong offset. It can never be (0,0,0). If the two faces are in the same direction as one of your axis then offset will be (X,0,0) where X is the distance between them. |
March 4, 2015, 05:53 |
#13 |
Javi
Rep Power: 16 |
Hi guys,
I don't know exactly if you are looking for something like this video: Make periodic bc in Fluent |
March 10, 2015, 20:05 |
#14 |
Renato Venturatto Junior
Rep Power: 12 |
I have a question for you guys...
Do the boundaries need to have an angle with respeect to the x-axis to set the periodic boundaries? I am trying to set the two horizontal boundaries in the picture attached as periodic... |
March 10, 2015, 21:39 |
#15 |
If you want to make it transitional, answer is no. I managed to give transitional condition using the consol. Previously, I tried with unstructured mesh it didnot work. When the mesh changed to structured mesh, it did work. Cheers. |
March 11, 2015, 23:24 |
#16 |
Jufri radin
Rep Power: 12 |
http://www.cfd-online.com/Forums/flu...-tutorial.html
Has a way to make a cyclic symmetry. Maybe it could be applied to your geometry |
periodic boundary condition (translational) fluent 6.3 | haihek | FLUENT | 3 | January 22, 2014 05:10 |
periodic boundary condition in fluent | farzadpourfattah | FLUENT | 2 | July 27, 2013 14:29 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Bug in fvc::grad() and periodic boundary condition | JBUNSW | OpenFOAM | 3 | November 15, 2012 04:09 |
Periodic boundary conditions in parallel fluent 6 | Newuser | FLUENT | 0 | May 7, 2003 10:26 |
