Steady state solution as an initial condition for a transient problem
Like Tree1Likes
  • 1 Post By adnanakhtar
Old   January 16, 2015, 17:21
Default Steady state solution as an initial condition for a transient problem
Adnan
adnanakhtar is on a distinguished road
I am relatively new to FLUENT and have a question on solution initialization of a transient problem.
I am working on a transient problem which involves a fluid and a solid domain. (Similar to a quenching problem)
The initial analysis that I did involves only the heat transfer in the fluid domain. For this case, I found out the steady state heat transfer solution.
The next step involves the transient heat transfer in both fluid and solid domains. I want to give the steady state solution in the fluid as my initial condition. The solid is at a fixed temperature initially.
When I look in the FLUENT options for solution initialization, I can only patch the liquid domain to a fixed temperature.
Is there a way by which I can import the results of my steady state solution as an initial solution for the transient case?
Thanks
adnanakhtar is offline   Reply With Quote
Old   January 17, 2015, 00:16
Zeng Liyue
soriyoshi is on a distinguished road
Thanks
I have a solution in my Evernote but actually i haven't tried it yet, so if something is wrong, please correct me.
You may do this:
File-Write-Case&Data;
File-Interpolate;
Write data and store a .ip file;
then Read and Interpolate with that .ip file.
soriyoshi is offline   Reply With Quote
Old   January 17, 2015, 00:21
Zeng Liyue
.....Just after I reply with that solution, I realized that method applies to interpolating data between different mesh solutions...Now I think maybe File-Read-Data will do......
Old   January 17, 2015, 04:06
amin.z's Avatar
Amin
amin.z is on a distinguished road
Thanks
hey Adnan!
Did you run a steady state simulation in fluent!?
if yes, of course that you can use these data for the transient simulation...
amin.z is offline   Reply With Quote
Old   January 17, 2015, 14:06
Adnan
Thank you for the reply Amin and Soriyoshi.
Yes, I was able to run the steady state problem.
The file read data would not work as it has 2 different meshes. (the steady state one with only the fluid and the transient one that I have with both the solid and fluid domains)
So when I tried file read data I got an error saying the mesh is different.
When I tried running the case by using the interpolation file, one problem that I faced was the values initialized weren't the same as the steady state solution. Instead a different fixed temperature was initialized in the liquid domain. Probably, because the coordinates of the steady state problem and the transient problem are different. I am not sure about this?
Is there a way by which I can specify the coordinates of the region where the interpolation file should initialize the data?
Old   January 19, 2015, 14:26
Adnan
I resolved the problem by solving the steady problem in the new domain by giving adiabatic conditions on the interface between the solid and liquid domain.
I used that as my initial conditions and got the desired results.
Thanks
arizwan likes this.
Old   October 24, 2016, 15:01
Smile
skywalker
M.Meki is on a distinguished road
Hello every one, I have a similar problem here. I am simulating water hammer in a pipe. The flow is turbulent so I simulated the flow first for steady state before a sudden closure of the exit valve.
The B.C were a fixed static pressure at inlet, and a fixed flow rate at exit
I need to use these conditions (including the generated velocity profile) as initial conditions for the transient simulation when the valve is suddenly closed.
The B.c I want to use are : the same static pressure at inlet and 0 velocity at outlet ( or maybe 0 flow rate at outlet)
I am not sure how I can do that in fluent.
Thank you in advance for your help.
M.Meki is offline   Reply With Quote
Old   November 25, 2016, 06:16
seyedashraf's Avatar
Omid Seyedashraf
seyedashraf is on a distinguished road
Send a message via AIM to seyedashraf Send a message via Yahoo to seyedashraf
Any updates?
I am going to conduct a similar numerical model.
seyedashraf is offline   Reply With Quote
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
rhoSimplecFoam Mach0.8 no pressure values CFDnewbie147 OpenFOAM Running, Solving & CFD 16 November 23, 2013 06:58
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 06:55
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
