how to add a total flow rate profile for the injection
Like Tree1Likes
  • 1 Post By DrFloyd
Old   January 8, 2015, 13:24
Default how to add a total flow rate profile for the injection
DrFloyd is on a distinguished road
hello to everybody,
I started today with fluent and i should study an injection spray in stagnant gas. I found out in a tutorial that it's possible to insert a flow rate profile in injection property selecting the box next "total flow rate", but i have only a "constant" value!!!
please help me to add a profile rate flow instead a constant value.
mohibanwar likes this.
DrFloyd is offline   Reply With Quote
Old   January 8, 2015, 16:42
François Grégoire
macfly is on a distinguished road
Simplest way is to use a user-defined function (UDF). Go through this tutorial and you will know how to use a UDF: https://www.sharcnet.ca/Software/Flu...lu_tg_vof.html
The UDF you're looking for is DEFINE_PROFILE, read this well documented (with examples) section: https://www.sharcnet.ca/Software/Flu...e_profile.html
There is a learning curve when you start to use UDF but don't panic, it's not that hard if you read carefully the UDF manual, and you will gain a lot of flexibility at using Fluent.
macfly is offline   Reply With Quote
Old   January 10, 2015, 08:28
Default spray penetration plot
Thank you macfly for the quick reply,
i resolved my problem following the instructions in http://www.arc.vt.edu/ansys_help/flu..._pp_trans.html.
I have another question now..i should want to plot spray penetration of 95% of mass in z axes as funcion of time.. but i don't know how to do...do you have any idea?
thank you again.
Old   January 10, 2015, 12:21
François Grégoire
Oh I thought you wanted to apply a profile varying in space. Indeed, the method you're using just fine to apply a simple transient profile.
I don't know how you could plot 95% of a variable. But nothing is perfect in CFD, it's a world of approximations, and IMHO 95 % of something is pretty much the same as 100% of something and you could just plot 100% of the penetrated mass and have a very good idea of the 95% result.
Old   January 10, 2015, 13:27
Default plot dispersed phase penetration
Dear macfly,
thank you for your reply, you are right can you help me to plot 100% of the penetrated mass in function of time in z axes? thank you
total mass loss/gain--simulating taylor couette flow nwpukaka OpenFOAM Programming & Development 0 February 12, 2014 19:57
is there a post processing keyword for obtaining mass flow rate and total mass? immortality OpenFOAM Post-Processing 29 July 6, 2013 02:08
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 04:24
Total shear rate in a 3 dimensional flow Bo Busk Jensen Main CFD Forum 3 May 23, 2003 16:26
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
