Moving wall with absolute speed 0m/s vs stationary wall
Like Tree1Likes
  • 1 Post By ghost82
Old   November 16, 2014, 23:28
Smile Moving wall with absolute speed 0m/s vs stationary wall
Yushi Zhu
andyzhu is on a distinguished road
I'm a little confused by the two sets especially in a frame motion.
The premise is that I used tanslational frame motion to simulate flow passing a ball which is set as a wall with no slip on surface.The thing is:
Case A:
I set the ball with stationary wall.And velocity contour shows the ball does have velocity profile on its surface.
Case B:
I set the ball with moving wall whose absolute speed is 0m/s.And velocity contour shows all the velocity-magnitude on the ball surface is 0.
In my opinion,I think case B is authentic since there's no slip on walls.But on the other side,I think "stationary" shoud equal to"moving wall with absolute speed at 0",what's the difference between case A and case B.
Thank you so much.
andyzhu is offline   Reply With Quote
Old   November 18, 2014, 00:46
Lucky
There shouldn't be any difference. Fluent sets the wall velocityto 0 m/s when you specify stationary wall. What you are doing is the same as what Fluent is doing internally.
Old   November 18, 2014, 05:01
Yushi Zhu
Thanks ,Tran.I agree with u.I think the calculated data is the same,while the way it shows differs.
Old   November 18, 2014, 11:56
Andrew Kokemoor
Kokemoor is on a distinguished road
If you are using a moving reference frame, stationary walls are always stationary relative to the cell zone. If you are specifying zero absolute velocity in Case B, you will get different results. If you specify zero relative velocity with a moving wall, you should get the same as Case A.
Kokemoor is offline   Reply With Quote
Old   November 18, 2014, 12:26
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I agree with Andrew. It's not straightforward, but I remember I read it in ansys' guide.
If you want to specify a fixed wall, always use zero absolute velocity.
sargordan likes this.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   November 18, 2014, 21:48
Yushi Zhu
Thanks Andrew,I guess "stationary" coincides with the reference whether it moves or not.
Old   July 9, 2016, 08:24
Default moving wall
alliche redha
cheredha is on a distinguished road
hi;
i want create a file profile for piston motion (.prof)
What software should I use it.
thanks;
cheredha is offline   Reply With Quote
boundary
Stationary wall in MRF AGP FLUENT 2 July 11, 2014 19:17
Apparent wind Speed (moving object) Solo Sails OpenFOAM Running, Solving & CFD 11 December 13, 2011 09:34
stationary wall vs. moving wall user0314 FLUENT 0 August 26, 2011 10:42
moving wall BC problem Sourabh Main CFD Forum 1 August 8, 2006 08:47
Values of k & epsilon in the moving wall ghlee Main CFD Forum 1 August 16, 1999 13:42
