October 19, 2014, 16:39 |
Direction-1 and Direction-2 in porous zone
Rep Power: 15 |
I am having a hard time trying to figure out what Direction-1 and Direction-2 mean exactly. Could you please give me examples? In addition, why are there differences in orders of magnitudes between components of viscous resistance and inertial resistance at different directions despite the isotropic media? I have seen this in some of the tutorials prepared for flow in porous media. For example, direction-1 component of viscous resistance has a value with order 10^7 whereas the other two have 10^9. Doesn't it matter even if I know those parameters for a certain porous medium? Where is the accuracy if I can manipulate the order of magnitude? Thank you |
October 19, 2014, 19:26 |
#2 | |
A-A Azarafza
Rep Power: 14 |
Hope it helps
Regard yours |
October 20, 2014, 05:44 |
Rep Power: 15 |
Thank you for your answer but I still do not know the influence of the directions. If the porous medium is isotropic, are the direction vectors supposed to be the same and non-zero?
October 20, 2014, 18:47 |
A-A Azarafza
Rep Power: 14 |
I don't understand what exactly you mean. But if the porous media is isotropic, the values of the permeability are the same for all three directions.
Regard yours |
October 21, 2014, 03:41 |
David Stanbridge
Rep Power: 16 |
highhopes, Direction 1 and 2 are defined in the same panel in which you enter the inertial loss factors. Usually Direction 1 is 1,0,0 (x axis) and Direction 2 is 0,1,0 (y axis). If the media is isotropic then the direction vectors should still be different. You will just specify the same loss coefficient for each direction.
October 21, 2014, 16:57 |
Rep Power: 15 |
Thank you for your answers,
The only information regarding the directions is the one written under title "Defining the Viscous and Inertial Resistance Coefficients" in Fluent user guide. Is there any source clearly explaining how the direction vectors are used and what they are for? Is it basically about how they lie in the coordinate system? Or does it have something to do with the main flow direction? If so, doesn't any transverse velocity component die out even in porous media with very high porosities? My medium is simply a porous cylinder whose axis is on x. Are the direction-1 and direction-2 vectors supposed to be (1,0,0) and (0,1,0), respectively? Thank you again |
October 22, 2014, 04:34 |
David Stanbridge
Rep Power: 16 |
Please refer to equations 6-1 and 6-2 in the Fluent Theory Guide 6.2.3.2 Momentum Equations for Porous Media. All of your questions are answered in the formulae. As you can see it will be a vector sum. For a porous cylinder then use the Conical option in the porous zone. Here you enter 1,0,0 as the axis vector, 0,0,0 for the cone axis (assuming that your cylinder has it central axis on the x axis) and then enter Direction 1, 2 and 3. For a cylinder the cone angle is 0. For the Conical option Direction 1 is tangential (i.e. along its length), 2 is normal to the cone surface (which is radial for a cylinder) and 3 is circumferential.
October 23, 2014, 03:36 |
Rep Power: 15 |
Thank you very much David.
June 28, 2017, 03:23 |
#9 | |
sofina
Rep Power: 9 |
June 28, 2017, 03:32 |
#10 |
David Stanbridge
Rep Power: 16 |
You will need to have a custom UDF for this in order to define the relevant vectors around the sphere.
June 28, 2017, 08:21 |
#11 |
sofina
Rep Power: 9 |
September 28, 2017, 15:08 |
solar chimney
#12 |
pezhman
Rep Power: 11 |
i am trying to simulate the 2d solar chimney in fluent.
i want to simulate solar storage layer as porous medium. what should i put for direction-1 vector X & Y? Capture.JPG |
September 28, 2017, 20:00 |
#13 |
A-A Azarafza
Rep Power: 14 |
For defining porous media, you You definitely need the porosity and permeability of your of your model. For the permeability you can use experimental data or you can use start with fluent default values. If the porous media is homogeneous, Of course the baggies for pime ability in exam Y direction would be the same but if it's anisotropic, the values would be different. You need to consider it as well.
Sent from my SM-G950F using CFD Online Forum mobile app
Regard yours |
September 29, 2017, 10:54 |
#14 | |
pezhman
Rep Power: 11 |
for viscoue resistance and inertia resistance i use the same value in both direction , but i dont know what is the value for X&Y direction for storage medium ,llll.JPG |
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 8 | May 30, 2024 03:59 |
FLUENT porous zone inputs | eishinsnsayshin | FLUENT | 19 | April 17, 2020 05:40 |
Porous zone input properties | chaudhry_hashim | FLUENT | 0 | September 10, 2014 03:48 |
Direction vectors and adsorption in porous zones | Toplaa | FLUENT | 0 | August 16, 2013 15:22 |
Porosity profile, dividing a zone, or getting zone location from zone | khoopes | FLUENT | 0 | June 2, 2012 20:39 |
