DNS using Fluent 15.0
Like Tree2Likes
  • 1 Post By ghost82
  • 1 Post By adnan.nweilati
Old   October 17, 2014, 17:40
Unhappy DNS using Fluent 15.0
Adnan Nweilati
adnan.nweilati is on a distinguished road
Hello fellow Fluent users,
I'm currently doing my final year in Mechanical Engineering. The dissertation topic I choose is basically a project aiming at direct simulation of turbulent flow without using turbulence models.
In other words, I have to preform DNS on Fluent (I was told by my adviser that I have to work with Fluent).
After going through this website's threads, I can say I have a good idea about DNS and how crazy it is in term of computational power and time consumption.
However, there is a question that I'm really confused about. How am I going to perform the DNS without the model itself. Does that mean I don't have to create a model in ICEM? (the software I was taught how to use for creating mesh grids)
Or do I create a really simple geometry (like a rectangle) with a really really fine mesh inside it and choose laminar flow as viscous model?
Please help this confused student
Thanks!
adnan.nweilati is offline   Reply With Quote
Old   October 18, 2014, 11:05
ghost82's Avatar
Rick
ghost82 will become famous soon enough
It is theoretically possible to perform DNS in fluent: "all" you have to do is to create a very fine mesh (able to resolve the kolmogorov scale), choose the laminar model and make a transient simulation with a very small time step (turbulent time scale).
I hope you have a very big cluster and a lot of memory......
Jomid likes this.
ghost82 is offline   Reply With Quote
Old   October 18, 2014, 11:26
Adnan Nweilati
Correct me if Im wrong but this is how Im going to approach this:
- Create a simple rectangle in ICEM and specify the inlet and the walls
- Create the fine mesh
- Go to fluent and choose the laminar model and make a transient simulation with a very small time step
- Hope my computer wont explode
Stevie_1200 likes this.
Old   October 18, 2014, 11:31
ghost82's Avatar
Rick
I think you will not be able to perform such an analysis without a big cluster and (with a big cluster) with a lot of time...
What's your Reynolds number?
However, basically the approach you described is correct.
Old   October 18, 2014, 11:46
Adnan Nweilati
Around 68000. My inlet speed is 10 m/s and my diameter is 0.1 m
Old   October 18, 2014, 11:50
ghost82's Avatar
Rick
There is an old post in cfd online about fluent and DNS:
http://www.cfd-online.com/Forums/mai...e-dns-les.html
From post #5 you can understand that you cannot perform this simulation without a very big cluster
You should have a mesh > several hundreds milions cells and time steps of the order of 10^-10 s
Who is the crazy person who told you about this project???
Old   October 18, 2014, 12:01
Adnan Nweilati
I choose it from a long list of topics
I didnt know about how complicated DNS was at that time!
Im getting really worried about this now
Old   October 18, 2014, 12:02
ghost82's Avatar
Rick
Can't you change the topic?
It is not possible to assign these topics to students without providing at least hardware to solve them...
Old   October 18, 2014, 12:15
Adnan Nweilati
Its not possible to change it since its been a month since we started.
Worst case scenario is that I have to at least perform RANS and LES instead of DNS.
Or maybe do the DNS but with an extremely small case and compare the results to RANS and LES.
Old   October 18, 2014, 12:16
ghost82's Avatar
Rick
Good luck my friend..
Old   November 21, 2014, 09:25
Thumbs up
  #11
venkatesh92 is on a distinguished road
An interesting study would be to compare performance of different turbulence models. There is plenty of literature out there for validation. Good luck!
venkatesh92 is offline   Reply With Quote
Old   November 21, 2014, 15:40
B_Kia
HyperNova is on a distinguished road
hi my friend
i read a paper few months ago , they modelled a very small geometry about 24cm^3 and Re = 180 , the mesh was about 10million and the computer had 11000 cores! this the paper you can find it on google scholar :
title : Influence of Bubbles on the Turbulence Anisotropy
Igor A. Bolotnov
Department of Nuclear Engineering, North Carolina State University, Raleigh, NC 27695
HyperNova is offline   Reply With Quote
Old   November 25, 2014, 08:47
Adnan Nweilati
Hi, would you mind telling me the best literatures for validation? I tried searching for weeks for something similar to my dissertation topic but I had no luck.
A possible reason for this is that my researching skills are still poor, so I don't really know how to look a good paper.
Thanks
Old   November 27, 2014, 05:37
You could probably use Science direct or google scholar. Unless you have a clear idea of what you want to get out of your simulation, it is very hard to find a proper literature. Once you do that, you will discover that there are more than sufficient experiments available to validate your cfd predictions....
Old   March 13, 2023, 09:52
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Dear Adnan,
DNS actually does not require any turbulence model. Your title was misleading since DNS does not use any turbulence model. If it had to, then what was the need to do DNS? Modeling was enough. Anyways, DNS wants a very very fine grid. From Turbulent Flows by Pope, DNS simulation has cost Re^(9/4) in each direction. I mean your each direction cells must be proportional to Re^(9/4) for capturing a DNS flow. This will make the computation extremely heavy.
Regards,
SJ
Shamoon Jamshed is offline   Reply With Quote
ansys, cfd, dns, fluent, icem
How to start Fluent with Matlab?? Jay Hu FLUENT 8 November 9, 2022 07:30
DNS in FLUENT rajani FLUENT 9 May 3, 2021 01:55
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
