inlet/outlet settings on symmetric analysis
Like Tree2Likes
  • 1 Post By CeesH
  • 1 Post By CeesH
Old   October 14, 2014, 19:52
Question inlet/outlet settings on symmetric analysis
sozen is on a distinguished road
for fluent flow BCs how can i define outlet area if the area is on the symmetric side as shown below
sozen is offline   Reply With Quote
Old   October 14, 2014, 22:43
Cees Haringa
CeesH is on a distinguished road
Hello Sozen,
This geometry is not symmetric, since there is a flow crossing your current 'symmetry plane'. In order to make the geometery symmetric, you need to make the cut horizontal, instead of vertical as it is now (I assume the geometry is 2D?) Then you can simply specify a velocity inlet with the same velocity as usual (so it gets half the total volumetric flow) and a pressure outlet.
Cheers,
Cees
sozen likes this.
CeesH is offline   Reply With Quote
Old   October 15, 2014, 00:29
Originally Posted by CeesH View Post
Hello Sozen,
This geometry is not symmetric, since there is a flow crossing your current 'symmetry plane'. ...
Thank you for your advise Cees,
Does this means "the flow have to be symmetric in symmetry method"?
So, let's assume the problem is two flanged pipe and there are two symmetric fans inside the flanged area(3d). Can't we solve this with symmetry method?
Old   October 15, 2014, 02:06
Cees Haringa
Indeed, the flow has to be symmetric in order to exploit symmetries.
You can indeed use symmetry on a flanged pipe with some kind of fan in there, provided it is symmetric. For example, if the fan has 6 blades, you might model only 1 blade, and a 60 degree section of the pipe, and assume a periodic symmetry.
Best,
Cees
Old   October 15, 2014, 02:21
Best,
Cees
i don't know if i can use the periodic symmetry due to helix shaped blades and small gaps between them. But i'll try, thanks a lot.
Old   October 15, 2014, 03:19
Cees Haringa
Helix shaped blades may indeed be a problem.. Anyway, good luck!
sozen likes this.
bcs, boundary conditions, symmetry bc
How to implement a sensitivity analysis for certain items Mason liu CFX 10 August 17, 2017 09:46
Is symmetric tensor assumed in CFD? andyCas Main CFD Forum 6 June 26, 2014 09:02
Acoutic fan analysis arunraj CFX 3 October 4, 2012 19:54
Eigenfrequencies static and modal analysis Laura_mecheng ANSYS 1 May 15, 2012 04:40
3D analysis of Ahmed body Irshad22 FLUENT 0 December 17, 2009 05:33
