Two-phase flow though porous media - gas and liquid permeability
Like Tree2Likes
  • 1 Post By swiftaircraft
Old   October 9, 2014, 11:39
Default Two-phase flow though porous media - gas and liquid permeability
Rui_27 is on a distinguished road
I would like model a two-phase flow (air and water) through a porous media using the VOF method.
My question is do I have to set different permeability for each phase (liquid and gas)? Or the permeability is the same for both phases? If not, How can I related liquid and gas permeability?
Many articles just mentioned one value for the permeability when simulating two-phase flow through porous media. But in Fluent you have to set the permeability for each phase...
Can anyone give some insights about this? I would appreciate!
Rui_27 is offline   Reply With Quote
Old   October 20, 2014, 13:44
Bill Wang
6863523 is on a distinguished road
Hi Rui_27,
To simulate the flow in the porous media, I set the viscous/inertial resistance in fluent.
Acctually,I am facing a similar questions right now.
In my simulation, the porous wick is saturated with liquid water. However, evaporation occurs at the surface of the porous wick.
Should I set these parameters for water vapor?
6863523 is offline   Reply With Quote
Old   October 21, 2014, 03:28
David Stanbridge
swiftaircraft is on a distinguished road
Rui, You should use the same permeability in this case. Just change the inertial resistance factors if they are different for air and water through the medium that you are modelling.
Rui_27 likes this.
David Stanbridge
Swift TG Solutions Limited
www.swifttgsolutions.com
swiftaircraft is offline   Reply With Quote
Old   October 22, 2014, 10:49
Hi David, thank you for your answer!
I have now another question about porous media formulation in Fluent that i think you might be able to help me.
I did some preliminary simulations changing the porosity of the media, and i obtained some surprising (at least for me) results: increasing the porosity makes water to flow "slower" in the porous media, and i was expecting the opposite!
I found in Fluent's manual that porosity only affects heat transfer properties (which i am not considering) and the time-derivative in the continuity equation. However, I don't understand how can this lead to the results i obtained.
Can you give some insights about that? thanks!
Old   October 22, 2014, 10:52
David Stanbridge
Did you change any of the inertial or viscous loss coefficients?
David Stanbridge
Old   October 22, 2014, 11:02
No, just the porosity. Attached a picture with the results i mentioned.
Some details about the simulations:
I am modeling two-phase flow (water and air) through a channel that as a porous and a non-porous region.
Air is entering at the upper part of the channel (from left to right) while water is entering at the bottom part of the channel (the porous media) and through a porous directly into the upper part of the channel.
Old   October 22, 2014, 11:35
David Stanbridge
Do you have the "Relative Velocity Resistance Formulation" turned on?
David Stanbridge
Old   October 22, 2014, 11:40
Yes, Relative Velocity Resistance Formulation is on.
I just set 1E12 for the viscous resistance in all directions, and the porosity of the porous media.
Old   October 22, 2014, 11:54
David Stanbridge
A porosity greater than 1 makes no sense. If the porosity is 0 then it is solid. If the porosity is 1 then it is an open volume. Therefore setting it to 1E12 is not correct. Are you interested in viscous resistance in this simulation? 1E12 is very high if it is not based on anything physical.
David Stanbridge
Old   October 22, 2014, 12:40
Sorry, i was not very clear in my previous message. I set 1E12 just for the viscous resistance! For the porosity I tried 0, 0.1, 0.5 and 1. For porosity of 0, the solution diverged on the first iteration because as you said the porous media become a solid, and water cannot move through a solid. That i was expecting. But when I increase the porosity, water moved faster through the porous media with 0.1 of porosity and slower when the porosity was 1. That is what I can not understand... i was expecting that water would move more easily for larger values of porosity.
Old   October 22, 2014, 13:46
David Stanbridge
With a low porosity the physical velocity is higher and therefore the water would seem to flow faster. Essentially at low porosity there is less open volume and therefore for a given inlet volumetric flow the time to fill will reduce. At a porosity of 1 the volume is at its maximum and therefore the time to fill is longest.
Rui_27 likes this.
David Stanbridge
Old   October 22, 2014, 13:52
David, thanks a lot for your help and patience!
I now understand the results i obtained.
best regards
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
phase change with multiphase flow in porous media lacaillg Fluent Multiphase 1 February 10, 2018 06:28
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 08:10
error message cuteapathy CFX 14 March 20, 2012 07:45
Gas dissolution from liquid phase with CFX Roger Young CFX 2 May 6, 2008 08:37
