Convergence issue - combustion and wall heat transfer
Like Tree1Likes
  • 1 Post By MachZero
Old   October 9, 2014, 11:14
Unhappy Convergence issue - combustion and wall heat transfer
MachZero is on a distinguished road
Combustion community,
I am having a really troubling problem. I am simulating combustion in Fluent using the non-premixed model. I have two inlets fuel streams and a single oxidizer stream. When I model the combustion, I get spikes in my turbulence and continuity residuals every 10-20 iterations, but the outlet temperature converges well and the heat flux balance at the end of the run is close to zero.
Then I add in a heat flux through the walls, using an exterior heat transfer coefficient and bulk temperature. Once this happens, the outlet temperature has swings of up to 100 degrees C and the heat balance way off balance.
I have been working this model for days (long, 12+ hour days) with almost no progress. Has anyone seen this, or have any ideas why this might be occurring?
ANY ideas are welcome!
I have added some plots of outlet temperature fluctuations and residuals
Phanindra Raavi likes this.
MachZero is offline   Reply With Quote
Old   October 9, 2014, 15:32
Default update
Update,
I was using the pseudotransient solver with low URFs on a poly mesh. I have seen to get a more consistent outlet temperature with a segregated solver, but the convergence is pretty poor when looking at residuals. There are a lot of spikes.
Old   October 11, 2014, 14:52
Default reply
Anonymous
Industrial_CFD is on a distinguished road
I would contact support...
Industrial_CFD is offline   Reply With Quote
Old   October 11, 2014, 15:32
François Grégoire
macfly is on a distinguished road
No so fast on the support, lots of details are missing.
As a first guess, I think mesh and timestep can have a big influence on your case :
1. Ask on the ANSYS Meshing & Geometry forum how you could make a structured mesh.
and/or
2. Reduce the timestep and see if it affects the oscillations.
macfly is offline   Reply With Quote
combustion modelling, convection heat flux, convergence issues, heat transfer balance, turbulence modeling
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
