reading boundary conditions data at inlet from .dat file
Like Tree1Likes
  • 1 Post By pakk
Old   September 17, 2014, 04:21
Default reading boundary conditions data at inlet from .dat file
Iman
engineer.iman is on a distinguished road
Hi
i have tabulated data of velocity, k and e from actual experiment in .dat type. how can i set fluent to read from this file for the inlet conditions? also if i want to set k-e using the relationship e=C*k^1.5 how and where to specify that?
any help/advice or reference is highly appreciated
engineer.iman is offline   Reply With Quote
Old   September 17, 2014, 07:30
pakk will become famous soon enough
You should write a UDF for that. Look in the UDF manual for DEFINE_PROFILE, there are some examples that might help you further.
engineer.iman likes this.
pakk is offline   Reply With Quote
Old   September 17, 2014, 21:02
Iman
Thank you Pakk for your comment, i will dig into the guide and see how i can write this UDF!!
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
