Boundary condition of velocity inlet
Like Tree2Likes
  • 1 Post By virendra_p
Old   September 10, 2014, 10:30
Question Boundary condition of velocity inlet
Sa.Baraty
sara22 is on a distinguished road
hello guys
i simulate shell&tube heat exchanger in fluent. i use velocity inlet boundary condition. now i question that i must select which options in turbulence part of velocity inlet boundary condition?
K and ep.
intensify and length scale.
intensify and velocity ratio.
intensify and hydraulic diameter.
thanks
sara22 is offline   Reply With Quote
Old   September 13, 2014, 01:42
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
It depends on your problem and inlet geometry but in most cases, the third option is more straightforward.
Regard yours
A CFD free user is offline   Reply With Quote
Old   September 13, 2014, 02:43
Sa.Baraty
tanks about your Ans.
I don't know why mass flow rate at inlet and outlet not be equal?!
this heat exchanger has two fluid domain (Water&Oil).
water: inlet - velocity inlet
outlet - pressure outlet
Oil: inlet - velocity inlet
That this domains are coupled(Thermal condition) together.
for example mass flow rate at inlet and outlet :
water inlet= 1.132
water outlet=0.746
oil inlet=0.171
oil outlet=0.521
thanks
Old   September 13, 2014, 15:28
Virendrasingh Pawar
virendra_p is on a distinguished road
Use intensity and hyd. dia bc. option...you can find empirical relations for I and D involving velocity and geometry data in fluent user guide....just looking at those mass flow rates gives me the impression that water is entering into oil flow domain...some sort of leakage...please check your geometry construction ..... Good luck!
sara22 likes this.
virendra_p is offline   Reply With Quote
Old   September 14, 2014, 02:45
Sa.Baraty
tanks about your ans.
my geometry is ok. i think my mesh file is not suitable.but i cant improve mesh file. its very complex.if possible i send ansys file(project-workbench) for you that you check it.email address please?
thanks
Old   September 14, 2014, 03:03
Virendrasingh Pawar
vdp6786@hotmail.com.... I'll have a look
sara22 likes this.
Old   September 14, 2014, 11:16
Sa.Baraty
i send project file for you .
thanks about your att.
thanks
Old   September 15, 2014, 11:57
Virendrasingh Pawar
Hi....i got the file but unfortunately your ansys is newer so files couldn't be supported by my system...is there any way around?
Old   September 15, 2014, 13:44
Sa.Baraty
Thanks. i sent 'stp' file of my model for you
thanks
Old   September 18, 2014, 21:14
Virendrasingh Pawar
Hi...i got the geometry....just one doubt...the end where the tube-side fluid (i guess oil in your case) reverses (the semi-sphere at top end)....shouldn't there be plates installed...or else shell-side fluid (water) will intermix...please clear
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
velocity profile inlet boundary condition question Lcw FLUENT 3 August 3, 2012 06:53
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
