mesh interface in Fluent
Like Tree8Likes
  • 2 Post By AvaShahrokhi
  • 2 Post By ghost82
  • 2 Post By ghost82
  • 2 Post By kad
Old   August 29, 2014, 08:37
Angry mesh interface in Fluent
Ava
AvaShahrokhi is on a distinguished road
Hi everybody
I have a question about the mesh interface. I have a domain in ICEM that has an unstructed tetra and hexa mesh next to each other. I have generated two faces at the same location in the interface on with structured mesh and other with unstructured tetra mesh and defined both as 'interface' in the boundary condition.
Once I read the mesh file in Fluent, I go to the interface option to pair the two faces and I can do this. However, Fluent defines a 'wall' for this interface and add it to boundary condition as 'wall' with zero face (I can not display this wall!).
Is this correct or I am making a mistake in defining the interface?
Thank you very much in advance!
AvaShahrokhi is offline   Reply With Quote
Old   August 29, 2014, 08:47
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I think this is correct.
Daniele
jamalf64 and AvaShahrokhi like this.
ghost82 is offline   Reply With Quote
Old   August 29, 2014, 08:55
Ava
Many thanks Daniele for your reply!
So do you think that this imaginary wall acts as a real wall in the boundary condition? e.g., if I have a vortex in the unstructured part, close to this wall, it will be limited to this wall rather than continuing in the structured domain?
Ava.
Old   August 29, 2014, 09:00
ghost82's Avatar
Rick
In reality I don't know why fluent create wall when an interface is defined.
Your interface will not act as a wall, fluid is allowed to go from one zone to the adjacent through the interface.
Here (point (d)):
http://aerojet.engr.ucdavis.edu/flue...ug/node176.htm
you can read that this is ok.
Daniele
Old   August 29, 2014, 09:04
Ava
Thank you very much!
Ava.
Old   August 29, 2014, 10:10
kad
kad will become famous soon enoughkad will become famous soon enough
"Wall" is the boundary condition for those faces on the interface that do not overlap with an adjacent face. E.g. this can be the case when you have sliding mesh interface with translational movement.
caio.df and Lipz like this.
kad is offline   Reply With Quote
Old   August 29, 2014, 10:32
Ava
Kad,
Thank you very much for your comment. I do not have a translational surface. I have just an unstructured mesh and a structured mesh that wish to connect them through mesh interface. This is inside my domain so I really do nit wish to have a wall there!
Ava.
Old   August 29, 2014, 10:43
Julez
Cucko is on a distinguished road
Originally Posted by AvaShahrokhi View Post
Hi everybody
Hey,
try to change the "interface" at the boundary conditions to a Wall part and then from a wall to a interior part. Maybe this will help you.
Greetings cucko
Last edited by wyldckat; August 30, 2014 at 13:35. Reason: moved the reply from a duplicate thread, because the OP asked in the main forum as well
Cucko is offline   Reply With Quote
Old   August 30, 2014, 04:52
ghost82's Avatar
Rick
Oh yes, now I remember!
If you have 2 surfaces, one bigger than the other, you can set the interface and for the non overlapping surface the default wall boundary condition will be applied (the new surface wall-xx).
Obviously you can change this wall boundary condition.
But this is a case different than yours.
So, your setup for interface is ok if you have 2 identical overlapping surfaces.
See attached example (interface created with surface 1 and surface 2)
Daniele
Old   August 30, 2014, 05:47
Anonymous
marauder is on a distinguished road
Seems like there is one more zone or plane in between these two zones which fluent is considering as solid. Most probably this happens when there are contact regions in Ansys mesh between two solids, in which case you haven't defined your bodies properly i.e., either solid or liquid. Which cad and meshing interface have you used??
marauder is offline   Reply With Quote
Old   December 25, 2020, 08:58
Default Do mesh interface allows mass to flow through it?
  #11
lipz paul
Lipz is on a distinguished road
Hello Kad, I have a problem related to what you said here. Torpedo is ejecting from a launch tube. I attached a picture of my boundary conditions. Pressure inlet is unsteady that i done through udf. I used dynamic layering option in Fluent for mesh movement. Fluid near to torpedo and Torpedo edge i set as rigid motion and remaining stationary. I created the interface as you see in the picture.(just selected the common edges of both faces and manually create the mesh interface without selecting any mesh interface option like periodic, coupled etc). How i created the mesh interface is, I just make line in the modeller and slice the body to two bodies. 1) fluid body near to torpedo 2)outer fluid.
My problem is, After the mesh motion I mean after some iterations, the torpedo is moving but in the interface the wall like effect is coming. It seems like after the torpedo came out, there is wall like effect on the outer part of torpedo. Its like torpedo is ejecting with tube on it. Why there is no smooth tranfer is showing in the interface boundary. Its like fluid is hit on a wall created in the interface.
Sorry for my poor english. I hope i conveyed my problem. Thanks for user assistance in this regard. Any other peoples help also much appriciated.
Thank you all
Lipz is offline   Reply With Quote
FLUENT - ICEM / Segmentation Violation Error (Hybrid Mesh) Joachim ANSYS 3 April 24, 2016 17:52
[Other] Pointwise Mesh into Fluent - Error: "Divergence detected in AMG solver: ads-0." kyles.sverige ANSYS Meshing & Geometry 3 January 27, 2015 13:28
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Frozen Rotor 1:1 Mesh Connection pharley CFX 5 January 31, 2013 17:15
