August 29, 2014, 05:36 |
Fluctuating velocity
Prasun Dutta
Rep Power: 12 |
Hi
I am working on turbulent pipe flow problems, three dimensional. I am trying to find out the values of fluctuating velocity of all three components, u',v',w'. Mean velocities inform of velocity magnitude, velocities in x,y,z directions are available but not the fluctuation parts. Please help me. Thanks in advance.... |
September 4, 2014, 03:18 |
SHEIKH NASIRUDDIN
Rep Power: 13 |
In 'General' window tick on transient option. Then for getting u', v' and w' you need to switch ON 'Data sampling for time statistics' option in 'Run Calculation' window for transient flow before starting simulation.
September 4, 2014, 04:55 |
Alex
Rep Power: 49 |
You have several options.
You can run the case in steady-state using a Reynolds stress turbulence model to get the individual components of the Reynolds stress tensor. Or you can perform a LES or DNS to gather information about the fluctuations. |
September 4, 2014, 10:04 |
Prasun Dutta
Rep Power: 12 |
Thank you all...
September 12, 2014, 01:33 |
Prasun Dutta
Rep Power: 12 |
Dear nasir i have done the simulation as per your suggestions..and now i am facing problem to collect data. from where i can get the u',v',w' etc? i am a beginner in post processing. please help me.. thanks
September 12, 2014, 03:46 |
SHEIKH NASIRUDDIN
Rep Power: 13 |
Hi Prasun,
Follow the sequence: 1. Open xy plot window 2. Mention plot direction for your case. 3 On the right of xy plot window, under Y axis function, open the first dropdown list and select unsteady statistics. 4. There after, in the 2nd dropdown list, you will find rms quantities. 5. Before opening xy plot window, you have to define the line or surface in your domain where you want the plot using following sequence:surface>line/rake or plane>define your line/ plane with specific name. 6. This new surface will be seen in xy plot window under surfaces. select the newly defined surface and click on PLOT. I think this may help you. |
September 16, 2014, 06:01 |
Prasun Dutta
Rep Power: 12 |
Thank you nasir... its help me a lot.. thanks again
March 19, 2015, 04:27 |
Prasun Dutta
Rep Power: 12 |
From fluent the RMS values of velocity fluctuation can be obtained but these are mean values(<u'^2>) how can I get fluctuation velocity (u') with time?
Thanks in adv............ |
March 19, 2015, 08:59 |
Temporal fluctuation
#9 |
SHEIKH NASIRUDDIN
Rep Power: 13 |
Hi Prasun,
If you want to calculate temporal velocity fluctuations, follow the below steps: 1. You need to define the point/points in the domain where you want to calculate the fluctuating components. 2. Then go to Monitors> Surface monitors. 3. In surface monitor panel:Name(file name)>Write(click and write the location where you want to save file)>X axis(choose flow time)> Get data every (choose time step)>Integral (you can choose vertex avg or any suitable)>Field variables(choose velocity) and then your required component>Surface(choose the point you have defined> OK. 4. Then in the directory you specified, under the file name at every time step data (instantaneous value)will be stored. 5. In FFT, there is option for subtracting mean from instantaneous quantity of temporal data. I hope this may be helpful to you. |
March 24, 2015, 07:57 |
#10 |
Prasun Dutta
Rep Power: 12 |
thank you nasir.. it works .. in this way i got temporal velocity fluctuations for different points.. but in my problem i have to calculate velocity fluctuations for a lots of points, so is there any option from where i can easily get values of all the points or i have to make separate surface monitor for different points? Like if I create a line or rake or something. Actually my problem is a simple pipe flow simulation, i want to get values of u',v',w' at different locations.
March 24, 2015, 08:47 |
Fluctuations
#11 |
SHEIKH NASIRUDDIN
Rep Power: 13 |
Hi Prasun,
Can you tell me, by getting fluctuating components of the velocity field,1. what do you want plot? 2. Plotting along axial location or diametrical location? 3. Plotting of temporal or spatial data? |
March 25, 2015, 03:51 |
#12 |
Prasun Dutta
Rep Power: 12 |
Actually I want to plot total turbulent kinetic energy budget in different axial and redial direction in a pipe bend flow. Reynolds stress transport equation can be defined as:
∂k/∂t= Pk + εk + πk + Dk + Tk − Ck where (i) Production (Pk) = −<uiuj> ∂Ui/∂xj (ii) Dissipation (εk) = −ν <∂ui/∂xj∂ui/∂xj> (iii) Pressure diffusion (πk) = −1/ρ ∂(<pui>)/∂xi (iv) Viscous diffusion (Dk) = (ν/2) ∂^2(<uiui>)/∂xj^2 (v) Turbulent diffusion (Tk) = −(1/2) ∂<uiuiuj>/∂xj (vi) Convection (Ck) = <uj>/2 ∂(<uiui>)/∂xj That's why i need u',v',w' plz find the attachment for better understanding of positions where i want to obtain the values of u',v',w'. Thanking you nasir for your help... |
October 20, 2020, 15:20 |
#13 | |
Italia
Rep Power: 6 |
October 30, 2022, 23:39 |
ask for help
#14 | |
Jinjun Ye
Thanks for your reply! |
October 30, 2022, 23:43 |
#15 | |
Jinjun Ye
thanks |
fluctuation velocity, turbulent flow |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 05:58 |
Velocity profile disturbance due to loss coefficient | rks171 | Main CFD Forum | 3 | May 25, 2012 18:30 |
LES : fluctuating velocity algorithm | Frank | FLUENT | 0 | February 5, 2006 04:54 |
HOW to GET FLUCTUATING VELOCITY COMPONENT at FLUEN | Seyfettin | FLUENT | 2 | December 1, 2005 04:51 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
