Cell Zone Conditions initialization Problem
Like Tree1Likes
  • 1 Post By ansys_matt
Old   August 21, 2014, 11:24
Default Cell Zone Conditions initialization Problem
ansys_matt is on a distinguished road
I am trying to simulate methane combustion in a tank. To start, I set the model to species transport with an inlet bringing in a mixture of methane-air (the fluent database mixture) from one inlet. The tank is open on the other end which I set as an outlet.
My question is this: I set the Cell Zone Conditions to the methane-air mixture (a fluid). But after the solution is calculated and I check in cfd-post at the first time step, the concentration of both methane and O2 (in fact all species) are zero everywhere inside the tank until it starts coming in from the inlet!
Why is the concentration of all species zero when I set the cell zone conditions to be the methane-air mixture? It appears that the only methane (and the only 02) is coming in from the inlet as the solution moves forward in time. How can I begin the simulation with the methane-air mixture already inside the tank (and thus a non-zero species concentration from the start)?
I thought that is what the Cell Zone Conditions setting did??
Thanks.
ansys_matt is offline   Reply With Quote
Old   August 21, 2014, 14:38
Default Edited question
I edited my question so hopefully it is clearer.
Please help!
Old   August 22, 2014, 16:47
Default Solved
I solved this by using a UDF to initialize before solving. Here is the contents of the UDF, for future reference. This is run only once before the solution starts, so it simply sets the correct values in all the cells.
   UDF for initializing species mass fraction.
   Uses C_YI(cell_t,Thread,Spec. num)
   This UDF should be run before solution initialization.
      Species 0 is Methane (Mass Fraction)
      Species 1 is O2
      Species 2 is H2O
      Species 3 is CO2
      Species 4 is N2
 #include "udf.h"
 DEFINE_INIT(my_init_func,d)
    cell_t c;
    Thread *t;
    real xc[ND_ND];
    /* loop over all cell threads in the domain */
    thread_loop_c(t,d)
         /* loop over all cells */
         begin_c_loop_all(c,t)
              C_CENTROID(xc,c,t);
                C_YI(c,t,0) = 0.056;
                C_YI(c,t,1) = 0.22;
                C_YI(c,t,2) = 0.0;
                C_YI(c,t,3) = 0.0;
                C_YI(c,t,4) = 0.724;
         end_c_loop_all(c,t)
saeed110 likes this.
Old   October 13, 2014, 05:45
Default matt
university
saeed110 is on a distinguished road
hi matt
thanks for your comment
how should i verify for fluent to know that, what is the species 1 or species 2?
thanks
saeed110 is offline   Reply With Quote
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
Export boundary setting in Fluent 14.0 asal FLUENT 4 September 28, 2017 10:40
Porosity profile, dividing a zone, or getting zone location from zone khoopes FLUENT 0 June 2, 2012 20:39
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
