drag and lift coefficient fluent
Like Tree2Likes
  • 1 Post By flotus1
  • 1 Post By tarjeiba
Old   August 8, 2014, 09:31
Thumbs down drag and lift coefficient fluent
bia
nabaouia
bia is on a distinguished road
its just my first workbench and it seems like a nightmare. . my problem is : a flow over a circular cylinder (diameter equal to 1 cm ) . the fluid is air .Reynolds number is 100 .unsteady .
i've tried to plot the drag and lift coefficient with fluent MONITORS ->FORCES ->DRAG ect . the ghraph givven is sinusoidal but the values are very low around zero. .and i must find 1.4 for the drag coefficient. . please help me
bia is offline   Reply With Quote
Old   August 11, 2014, 05:02
Tarjei
tarjeiba is on a distinguished road
You need to specify the reference values for the calculation of the drag coefficient. Remember,
D = \frac{1}{2} C_D \rho U_{\infty}^2,
where you need to provide the wanted flow variables. Fluent finds the drag force by integrating the pressure over the cylinder wall, necessitating a fine grid resolution. It then divides this by the applied reference values, giving you the calculated drag coefficient.
tarjeiba is offline   Reply With Quote
Old   August 13, 2014, 07:15
bia
nabaouia
THANKS TARJEIBA . but i've found somewhere that fluent gives you directly the drag and lift coefficient
. (that's why when i open the window of monitors
->drag -> edit ->surface = cylinder ) the choice of the surface is obligatory
so do you think that ther's a problem in the mesch (boundary layer ) or in the time step ?
Old   August 13, 2014, 07:28
Tarjei
bia, to be able to calculate drag and lift coefficients you need to set the values you are refering to -- this is just part of the nature of such coeffecients. When calculating for a cylinder, it is typical to give the resulting drag force in relateion to the dynamic pressure of the free stream flow values. However, Fluent has no way of knowing what these values are, hence your need to specify them.
Just go to go to Solution -> Reference Values to set the values you want Fluent calculate the coefficients in relation to.
As the drag and lift coefficients are not in relation to the near-wall flow field, there really is no way for Fluent to know what values you want it set to. However, you do need to specify what surface you want Fluent to integrate the pressure forces over, as you've mentioned.
Old   October 20, 2014, 06:46
bia
nabaouia
thanks i've tried this exp cylinder with diameter D= 15mm so refrence area = Pi* D . depth =1 and length = Pi* D/2 so i found a drag coefficient about 0.988and i want to have 1.33.
the computational box is 750x400mm2.
Re=150.
FOR THE RESIDUAL I SET 1 e-08
max iterations per time step =40
these are tha best values i've made to be so closer but i still far away .
i tried to change the depth i fixed depth = 1.33/0.988 , length =1 .and i found the results exactly like i hope but why i musn't do this the depth must be related to a geometric caractrestic and not a mathematical error or coefficient right ? so how to find the way ? please help me
Old   October 20, 2014, 07:27
Tarjei
Re=150.
bia, it seems I've given you insufficient information, apologies. I meant to say that the drag force should be expressed as
D=\frac{1}{2} C_D \rho U_{\infty} ^2 A,
where A is the area of the cylinder exposed to the stream. (The stream "sees" the cylinder as a rectangle of lenght L and height D.) Use this to set the reference lengths in Fluent.
(I still don't quite see why you need to run a simulation you seemingly already know the desired answer of.)
Old   October 20, 2014, 19:11
bia
nabaouia
thnaks a lot . in fact i must run the same calculation in a first step to be sure after this of any researched values ...i'll try really thanks a lot .
Old   October 21, 2014, 03:42
Tarjei
Ah. Of course, that makes sense ... and sounds like good practice. Good look on the remainder of your research.
Old   October 21, 2014, 18:23
bia
nabaouia
you are really great i've tried as mentionned and the results were perfect thank you a lot
Old   October 22, 2014, 04:27
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
You cant just change the reference values in order to make the results of a simulation match your expectations.
The results are inaccurate for some reason.
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
bia likes this.
flotus1 is offline   Reply With Quote
Old   October 22, 2014, 04:40
Tarjei
flotus1, of course I agree that you can't fine-tune your reference values to get the desired output. What you can do, however, as seems to have been bia's misstep, is to make sure that your provided reference values are of the same basis as the ones used in the calculations.
For the drag coefficient calculations, the typical reference area for a cylinder is the projected area (i.e., the diameter times the length of the cylinder), not the surface area of the cylinder.
bia likes this.
low values.
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Drag and Lift coefficient in Fluent pejmanpark FLUENT 0 July 13, 2011 13:11
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 11:52
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
