Dynamic mesh-defining deforming motion in cylinder |
July 31, 2014, 09:18 |
Rep Power: 12 |
Hello, I need some help in defining dynamic zones. My simulation consist of half cylinder with a nozzle in one end and piston surface on the other end of half cylinder. I would like to simulate some kind of needle, pushing piston inside cylinder and fluid leaving needle through nozzle. I have made 3 fluid zones, upper is defined as rigid body (include boundary layers close to piston) and wrote UDF with constant velocity, lower zone is stationary, but i have problem with middle zone.
I defined deforming motion, but when i preview mesh motion it does not deform. This middle zone is cylindrical shape and consist of boundary layers and tetrahedral elements in center. Do i need to write UDF for middle zone and what is easy way to connect this deforming zone with rigid body movement??? Thank you for helping |
August 1, 2014, 05:21 |
Rep Power: 12 |
I have found out that only first cell in deforming zone is really deforming, others are fixed no matter which meshing option do i choose.
I someone have solution to this, please help |
August 3, 2014, 09:49 |
Rep Power: 12 |
After I preview zone motion, error:" Mesh projection of deforming dynamic zones exceeds reasonable limits." shows up.
December 6, 2022, 10:20 |
M. Davis
Hi matix_tx did you finally solve your issue?
dynamic mesh zones |
Dynamic mesh motion using CFX | Anant | CFX | 13 | November 6, 2016 04:39 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Dynamic mesh motion based on calculation | Detian Liu | OpenFOAM Running, Solving & CFD | 0 | January 13, 2014 07:09 |
Dynamic Mesh _ Rotational Motion of a Rigid Plate | ROOZBEH | FLUENT | 2 | January 30, 2007 00:02 |
