How to calculate shear stress?
Like Tree4Likes
  • 1 Post By Entwistle
  • 1 Post By AGP
  • 1 Post By wxn
Old   July 7, 2014, 17:00
Default How to calculate shear stress?
AGP
Anonymous
AGP is on a distinguished road
I am trying to calculate the shear stress on the fluid on a user defined surface in the interior of the fluid. How can I do this? What is the formula to define a custom field function for this?
Thanks,
AGP
AGP is offline   Reply With Quote
Old   July 9, 2014, 04:06
AFM
Entwistle is on a distinguished road
Hi;
the shear stress, by its own definition, only can be computed on solid walls.
Regards.
Entwistle is offline   Reply With Quote
Old   July 9, 2014, 13:35
AGP
Anonymous
This user-defined surface is a wall. I am using a conformal mesh due to which all interfaces/walls are changed to interior regions in FLUENT.
Old   July 10, 2014, 03:28
Sangwoo Kim
swtbkim is on a distinguished road
Why don't you use Reports>Surface Integrals ?
swtbkim is offline   Reply With Quote
Old   July 10, 2014, 04:11
AFM
If these walls are changed into interior type, you will not be able to obtain the wall shear stress. In that case, you need to maintain these walls as walls (you can delete the mesh interface in the proper menu), so fluent will be able to show you the wall shear stress in Contours - Wall Fluxes - Wall Shear Stress.
Regards.
chaitanyaarige likes this.
Old   July 10, 2014, 17:34
AGP
Anonymous
But if I maintain them as walls, there will be no flow through them. This particular wall is the boundary between the fluid and a porous zone and I need to find the shear stresses on it. Can I write a custom field function to calculated the WSS for it?
Old   July 10, 2014, 23:05
Sangwoo Kim
I didn't try it, but how about this?
Make plane there by using sweep surface or Surface>Plane
and calculate wall shear stress about this plane
Old   July 11, 2014, 04:32
AFM
The problem is that the wall shear stress only can be computed on walls. One possible solution is to write an UDF that applies the definition of the wall shear stress, even if your surface is not a wall: You will need the velocity derivatives and the area vector of your surface. From the definition of the viscous stress tensor you can build it and compute the force vector on your surface and its magnitude. It would be something like that:
You can implement it on a DEFINE_AT_END if your problem is transient, or in a DEFINE_ON_DEMAND if it is stationary. You will also need use the Lookup_Thread in order to specify the ID of your surface and one UDM position.
Regards.
letsroll likes this.
Old   July 11, 2014, 10:29
AGP
Anonymous
I tried doing this in CFD post. I created a new expression to calculate the shear stresses. But when I compared the contours on a real wall - the results were qualitatively the same. But the numbers were way off. I am not sure how to proceed now.
Mwbadawy likes this.
Old   June 5, 2017, 04:51
wxn
sofina
wxn is on a distinguished road
I also want to know how to calculate the shear stress on interior surface of the fluid. Did you find the solution ?
wxn is offline   Reply With Quote
Old   July 23, 2020, 08:42
Mohamed Wael
Mwbadawy is on a distinguished road
I have the same issue. Did you find the answer?
Mwbadawy is offline   Reply With Quote
calculate y+ and u+ -how to get wall shear stress? Ralf Schmidt Main CFD Forum 18 September 17, 2019 04:23
Calculate velocity components from shear stress Arnoldinho OpenFOAM Running, Solving & CFD 0 August 29, 2011 13:07
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 07:41
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 02:45
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 08:43
