June 25, 2014, 03:52 |
Problem with compiling a udf
Naunidh
Rep Power: 12 |
I got this error report when I try to load the udf built -Please help
The UDF library you are trying to load (C:\Users\Admin\Documents\udf_trial_25thjune_files \dp0\FFF\Fluent\libudf) is not compiled for 2ddp on the current platform (win64). The system cannot find the file specified. C:\Users\Admin\Documents\udf_trial_25thjune_files\ dp0\FFF\Fluent\C:\Users\Admin\Documents\udf_trial_ 25thjune_files\dp0\FFF\Fluent\libudf\win64\2ddp\li budf.dll |
June 25, 2014, 04:21 |
Rep Power: 14 |
Hello guns_down,
do you have a Compiler installed? Last time I got this error there was no Compiler installed on my Computer. Fluent doesn't seem to have a built-in Compiler. Greets Nigirim |
June 25, 2014, 10:06 |
How to install a compiler??
Naunidh
Rep Power: 12 |
How to install a compiler?? I get this error as well when I try to calculate the solution...
C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.0\win6 4\2ddp\fl1450s.exe received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. |
June 25, 2014, 11:07 |
hannecart
Rep Power: 12 |
get same error but in 3d . if you find solution please share good luck .
June 25, 2014, 12:37 |
guns down
hannecart
Rep Power: 12 |
hey i got same problem as you !
And i suceed to solve it ! 1 install visual studio 2 install sdk 7.0 3 create a folder with file name.cas and udf.c 4 lauch sdk prompt command 5 go on the folder you create and lauch fluent from prompt command 6 On fluent use define function compiled should work this video may help you https://www.youtube.com/watch?v=GrLHn1Wc7Rg PS : which kind of udf are you making ??? most of udf can be interpreted dirctly from fluent . good luck and have fun it could take some time before success |
June 26, 2014, 03:46 |
Naunidh
Rep Power: 12 |
I have this C_UDMI in my udf thats the reason for error .. thanks any way for help...
August 25, 2014, 18:11 |
omidi
Rep Power: 12 |
hi
i have this problem when i calculate is started. i don't understand the solve of this problem that you explain, please clarify it for me ... thank you |
August 26, 2014, 06:23 |
#8 | |
Rep Power: 26 |
If you see:
Something went wrong when you tried to compile it. Look at the text that was written on the screen when you tried to compile, that will give a hint about what was wrong. |
August 27, 2014, 03:18 |
#9 |
omidi
Rep Power: 12 |
Than u Pakk
it's solved, thank u for your solution... |
About UDF compiling issues: 'nmake' | Haoyin Shan | Fluent UDF and Scheme Programming | 15 | November 4, 2019 19:05 |
Problem with compiling UDF in Fluent | amojodi | Fluent UDF and Scheme Programming | 4 | April 14, 2015 10:01 |
A problem about 'printf' and 'Message' in UDF. | LICH | Fluent UDF and Scheme Programming | 2 | May 2, 2013 03:45 |
HELP! Problem compiling UDF function | Syrakus | FLUENT | 6 | April 7, 2006 11:48 |
UDF compiling problem for 3D simulation | Marijo | FLUENT | 1 | March 28, 2006 04:21 |
